Installing 3 Ton Air Condition - HVAC - DIY Chatroom Home Improvement Forum
Old 07-30-2012, 09:01 PM   #1
installing 3 ton air condition
installing a 3 ton A/C in 1000 sf room with a 12" main how many vent will I need using 8" pipe for 1200 cfm
winning is offline   Reply With Quote
Old 07-30-2012, 09:14 PM   #2
If you mean round duct.
12" main duct is not enough for 3 ton. 3 ton needs 1200 cfm and 12" only is only used to carry 600 crm. to answer your other question 8" carrys 200 cfm but if you attempt ot have a 12" main and your unit does not freeze you will have increased the staic pressure and no one would be able to tell you the capacity of an 8". If it has to be round duct main you will need a 16".
You could split the main duct equaly and have the 12" duct coming off a plenturm kind of forming a T. This is not the most skilled way but will work.
turnermech is offline   Reply With Quote
Old 07-30-2012, 09:24 PM   #3
Rewards Points: 6,652
Sounds like a home work question to me. Have to love it when people use forums as search engines and never usually come back.
Old 07-30-2012, 09:38 PM   #4
Rewards Points: 582
none it won't work...
Old 07-30-2012, 09:38 PM   #5
I'm Your Huckleberry
Rewards Points: 2,270
3 ton for 1000 sf? Heat intensity, icky sticky.
Thanks.
Doc Holliday is offline   Reply With Quote
The Following User Says Thank You to Doc Holliday For This Useful Post:
ben's plumbing (07-30-2012)
Old 07-30-2012, 09:50 PM   #6
An old Tradesmen
Rewards Points: 6,112
LOL... Thats over sized even for your neck of the woulds.
The Following 2 Users Say Thank You to beenthere For This Useful Post:
ben's plumbing (07-30-2012), Doc Holliday (07-30-2012)
Installing new doors, floors, and trim. toobhed Windows and Doors 5 03-16-2012 03:21 PM
Installing vinyl fenching over chain link? rbove8 General DIY Discussions 3 05-02-2011 10:54 PM
Installing new wall receptacle... jaysen Electrical 18 06-10-2008 09:26 PM
Installing an island on floating engineered wood floor funktional Flooring 11 03-14-2008 07:19 AM
Installing laminate around doors??!! RonR Flooring 8 01-05-2008 08:38 AM
