Installed New Thermostat, Killing Fuses When Switching To Heat - HVAC - DIY Chatroom Home Improvement Forum
Old 11-01-2010, 12:33 PM   #1
Installed new thermostat, killing fuses when switching to heat
Hello all,
My upstairs and downstairs thermostats are both newer and apparently wired wrong. I went by the manual and I keep referring back to it but it looks like it's wired correctly according to that which is causing me a migraine, lots of confusion, and a cold miserable family. They are both Lux TX900TS thermostats. The A/C and fan work fine but when switching to heat it kills the fuses instantly. Can I get assistance on this please? Below are pictures of the way it's currently wired. Top picture is downstairs and bottom picture is downstairs.
carsnrockmusic is offline   Reply With Quote
Old 11-01-2010, 02:10 PM   #2
HVAC / Plumbing
the wiring at the t.stat may not match wires at the unit. Check t.stat wires at the unit. There's a short somewhere
kenmac is offline   Reply With Quote
Old 11-01-2010, 04:59 PM   #3
There are two and it worked before I installed the new thermostats. It's in my home's inspection (I changed them shortly after moving in to programmable ones). Just wanted to add that as I'm fairly certain it's the wiring on this side.
Old 11-01-2010, 05:47 PM   #4
An old Tradesmen
Rewards Points: 6,068
My guess, is that the blue wire. is a common, and if it is. it belongs on C.
Go to your air handler/furnace, and see if the blue wire is connected to C. if so, just move it to C on the thermostats, and you should be good to go.
Old 11-01-2010, 09:43 PM   #5
Thanks beenthere. I'm going to give this a try tomorrow. I spoke to someone from Lux and they said I may have the wrong thermostat? Does anyone know anything about this? Not sure how it could be the wrong one as I've got no experience with HVAC anything.
beenthere, on the downstairs one there's an extra wire that is black that doesn't exist in the upstairs wiring. I was going to move the blue one to common on that one and the upstairs. What should I do with the black? Cap it off?
Thanks for everything so far. Very much appreciate this. It's supposed to be in the 30's tomorrow...Have a lot of pressure on myself to get this solved.
Old 11-01-2010, 10:14 PM   #6
HVAC / Plumbing
you will need to look on the unit. wright down how it's wired & wire your t.stats the same . r to r, w to w, y to y, it b is on the c terminal at the unit. wire b to c at the t,stat. Do the same for both units
Old 11-02-2010, 05:21 AM   #7
An old Tradesmen
Was that black connected on the old thermostat? If not, yes just cap it.
Old 11-02-2010, 04:43 PM   #8
Rewards Points: 95
For blue, I always think "Cyan", so it's C.
Oh yeah, and for B, I think Orange = '0', unless it's an OddBall then it's 'B'.
garya505 is offline   Reply With Quote
Old 11-03-2010, 09:11 AM   #9
I hooked the blue up to common and it worked however the unit outside doesn't appear to be coming on so I think it's running off of electric and not the heat pump. If I'm understanding this correctly this could result in a huge electric bill.
Which honeywell thermostat should I buy for my Carrier heat pump? mannypp HVAC 29 01-30-2010 03:21 PM
How to test apartment Heat Pump tbrubes HVAC 7 02-04-2009 04:05 PM
programmable thermostat + heat pump Potomac101 HVAC 10 12-03-2008 11:02 AM
Which diagram to use on Lenox Thermostat wiring setup? Heat Pump Lenox techs needed twilightcall HVAC 1 08-13-2008 12:49 PM
radiant floor heat thermostat kornbln Electrical 5 03-27-2008 01:45 PM
