Installed New Ecm 2.3,and Blower Still Dances Around - HVAC - DIY Chatroom Home Improvement Forum
Old 04-11-2010, 09:11 PM   #1
Installed new ecm 2.3,and blower still dances around
Can faulty control board on 90 plus furnace make the variable speed motor dance around? The furnace is 98 model with 2.3 module.
lw1acguy is offline   Reply With Quote
Old 04-12-2010, 12:34 AM   #2
An old Tradesmen
Rewards Points: 6,158
Yes it can.
Did you use the motor for that model furnace. Or did you just get a ECM motor?
Did you follow the test instructions before condemning the motor?
Or an ECM motor tester?
Old 04-12-2010, 07:44 PM   #3
I checked motor,checked voltage to motor,And I did something my old boss told me to never do,which is assume..So it totally bit me in a**..I however did get instructions out of manual from carrrier to verify that it has a bad board.Oh and i think im going to get get motor tester,I only work on maybe 3 a year so i never got one.
Can doors installed brick be reversed FuLLTiLT Building & Construction 7 01-10-2010 08:52 AM
laminate wood flooring - after installed reds_21 Flooring 6 12-04-2009 08:22 PM
Framing an unfinished basement captainobvious Building & Construction 7 10-16-2009 10:53 AM
Granite not installed correctly???? debsc Kitchen & Bath Remodeling 7 02-01-2009 09:58 AM
Just installed LG dishwasher--there's a buzzing sound. naiLS1 Appliances 1 04-15-2007 10:22 AM
