Installed New Digital Thermostat - HVAC - DIY Chatroom Home Improvement Forum
Old 03-30-2012, 11:28 PM   #1
installed new digital thermostat
Hey guys,
A fellow newbie here.
I installed a new 5 wire digital thermostat to replace my old one back in December. The brand I'm using is a Hunter model # 42999B. It's a very simple model without any bells and whistles.
Anyways, after I installed the new thermostat, the heater worked fine.
Now, as the temp has gotten hotter here in Texas, the A/C will not turn on.
I tightened all the connections, checked all the wiring and even tripped the A/C switch on the main house panel in the garage. I'm not sure what I did wrong so I need some expert advice.
Now, my old thermostat had the wiring letters W, Y, G, R and C.
My new thermostat has the letters W,Y, G, Rh and Rc.
So naturally, I wired W>W, Y>Y, G>G, R>Rh and C>Rc.
BTW......the R wire is red and the C wire is blue.
Did I do anything wrong here?
Any advice guys?
khanrahal is offline   Reply With Quote
Old 03-31-2012, 12:00 AM   #2
REP
http://www.hunterair.com/ssi/pdf/hun...ers-Manual.pdf
Per instructions,disconnect the "C" wire and tape it off.reinstall the rh-rc jumper.
REP is offline   Reply With Quote
The Following User Says Thank You to REP For This Useful Post:
khanrahal (03-31-2012)
Old 03-31-2012, 12:04 AM   #3
OK, let me try this and get back to you.
Thxs for ur fast response !!!!
Old 03-31-2012, 12:40 AM   #4
DIY Enthusiast
sublime2's Avatar
Rewards Points: 504
Per the PDF,
On a 5 wire system there is no jumper?
Does the fan run when set to cool?
Does the compressor come on?
sublime2 is offline   Reply With Quote
Old 03-31-2012, 12:56 AM   #5
DIY Enthusiast
sublime2's Avatar
Rewards Points: 504
Heating or Cooling
Does Not Go On
or Off.
Erratic Display.
If unit continues to
operate in the Off
position.
Thermostat permanently
reads “HI”,
“LO”, or “Er”.
1. Replace Batteries.
1. Move HG/HE selector to correct
position.
1. Check that the function switch is in
the correct position (“HEAT” or
“COOL”).
2. There may be as much as 4-minute
delay before the system turns On -
wait and check. (Compressor
protection delay.)
3. Check your circuit breakers and
switches to ensure there is power to
the system.
4. Replace batteries.
5. Make sure your furnace blower door
is closed properly.
6. If your system only uses 4-wires,
be sure the jumper wire is installed
between the Rc and Rh terminals.
Old 03-31-2012, 01:03 AM   #6
Rewards Points: 6,652
Originally Posted by sublime2 View Post
Per the PDF,
Sublime, you need to read more carefully: "NOTE: Do not connect a “Common” wire (sometimes labeled “C”) to any terminal on this thermostat. Tape up the wire and do not use. This wire provides electricity to non-battery powered thermostats."
BTW, the OP has a 4-wire connection, not five wire. The OP needs to place the jumper back on RH & RC.
The Following User Says Thank You to gregzoll For This Useful Post:
Old 03-31-2012, 03:42 AM   #7
Problem solved !!!!
OK guys,
I took out the wire that I had put into the new thermostat's Rc terminal and taped it up.
I then found the jumper wire that came with the new thermostat and jumped Rh and Rc.
Final result?
SUCCESS !!!!!! THANK YOU THANK YOU THANK YOU ALLLLLLL FOR A JOB WELL DONE !!!!
It does turn out that I have a 4 wire system and that wire C is a common wire.
BUT..........here's the thing that threw me off from the start.
The old thermostat had the C wire connected to it. If this wire is supposed to provide power to thermostats that do not have a battery back up in them. Then why did my old thermostat have 2 AA batteries in it in the first place ????
Old 03-31-2012, 04:44 AM   #8
An old Tradesmen
Rewards Points: 6,824
Originally Posted by khanrahal View Post
OK guys,
Final result?
Many thermostats come with the ability to use batteries, or the 24 volts from the HVAC equipment. I always put the batteries in, since the customer paid for them. may be same reason your old stat had the batteries in it.
The Following User Says Thank You to beenthere For This Useful Post:
Old 03-31-2012, 06:59 AM   #9
biggles's Avatar
remove that C right "now" get it off the Rh terminal the Red goes to Rc there should be a little metal jump on Rc-RH.this is so both ssytems see the HOT R as your set in auto or swing it on systwem switch.the reason your sitting in cooling with no action Rc isn't seeing that HOT jump from Rh.the C wire has to be the other side of the furnace transformer ..so you have a solid 24V at the subbase reading it on Rc-C and Rh-C terminals with the stat removed.if you have a spare wire on the bell wire run up anycolor is cool to use...if not will walk you thru that flip and how to cheat to get your 24v up there.just for warning toggle off the furnace 115V before flipping wires... just to add..there is no jump between Rc-Rh because the Blue/C wire on Rc would of cooked the TR as a dead short
Old 03-31-2012, 11:13 AM   #10
DIY Enthusiast
sublime2's Avatar
Rewards Points: 504
Good think I wasn't the one with this problem...........
Old 03-31-2012, 11:24 AM   #11
biggles's Avatar
the batteries are a back up for a stat failure or power failure to save programs on repower..i you have a home power failure nothing is going to run anyway.3-AAA batteries are only 4.5VDC total not enough to swing relays down in the furnace 20' away
The Following User Says Thank You to biggles For This Useful Post:
Old 03-31-2012, 09:41 PM   #12
Hello,
I am not sure if I damaged anything electrical in my house. (I wouldn't even know where to look)
I know that now, I set my new thermostat to cool, it activates the A/C and when I set it to hot, it activates the central heater.
Should I be looking for something that could be possibly damaged by my doing? PLs let me know. Thxs
Old Wall Thermostat to New Digital Thermostat Problem steiny HVAC 3 02-02-2011 04:07 AM
Installed new thermostat, killing fuses when switching to heat carsnrockmusic HVAC 8 11-03-2010 08:11 AM
honeywell round digital non-programmable thermostat ALM HVAC 1 07-17-2010 01:31 PM
digital thermostat help please ss124fl HVAC 1 07-13-2010 04:13 AM
Frigidaire Heatpump/ Honeywell 3611 digital thermostat shanbrt HVAC 3 06-08-2009 07:27 PM
