Installed New Blower Motor Help - HVAC - DIY Chatroom Home Improvement Forum
Old 11-19-2010, 06:59 PM   #1
installed new blower motor help
I installed a new blower motor and now my furnace won't turn on. The Y and G light turn on but not the W. What should I check for???
pressman is offline   Reply With Quote
Old 11-19-2010, 08:22 PM   #2
HVAC / Plumbing
does the blower come on when you switch to fan on at t.stat. ? Check for 24 v from w to c. gas furnace ??
kenmac is offline   Reply With Quote
Old 11-19-2010, 10:27 PM   #3
I just check and I got 215v. What now? Please HELP:::
Old 11-19-2010, 11:07 PM   #4
Does all my led should be on? 2 out of 3 on my led lights are on. I need some heat. Someone help me PLEASE
Old 11-21-2010, 02:44 AM   #5
When I check the IFC, there was no volt to the inducer. But when I check the blower, the blower turns on. So, is my ifc gone bad?
Old 11-21-2010, 04:34 PM   #6
When I unplug the red/orange wires and plug the black/white in the motherboard the furnace turn on.
Old 11-21-2010, 04:53 PM   #7
An old Tradesmen
Rewards Points: 7,332
post pics.
Old 11-21-2010, 05:44 PM   #8
In the Rheem furnace there is a 5 pin plug. 3 black wire and 2 white one. And the other plug is like a 7 wire pin plug. This is 1red,1green,1blue,1pink, and etc. It look likes it plug from the mother board to the inducer. When I just plug the black and white one in the furnace turns on. but when I plug the other one in, it doesnt turn on. Is my motherboard bad?
Old 11-21-2010, 05:50 PM   #9
An old Tradesmen
Might be. might be the motor. might be the module.
take the motor to a motor shop. And have them test it.
Old 11-21-2010, 05:51 PM   #10
Here is the pic of it unplug.
Old 11-21-2010, 05:51 PM   #11
The blower motor turn on.
Old 11-21-2010, 05:56 PM   #12
An old Tradesmen
pic of motor.
Old 11-21-2010, 06:03 PM   #13
Everthing turns on when this plug is unplug. Even the inducer is working.
Old 11-21-2010, 06:04 PM   #14
See its unplug
Old 11-21-2010, 06:07 PM   #15
the blower motor. The blower motor turns on. Can it be a bad motherboard?
Bryant Plus 90 - No Blower Ducaticorse HVAC 13 01-03-2015 04:39 PM
Condensate only drains when blower stops sethmorgan HVAC 48 07-23-2011 03:32 PM
Blower shuts off even when set to 'on' fetzer85 HVAC 1 07-05-2010 11:48 AM
Condensor Good, Blower Bad ... ? jengel HVAC 3 05-07-2010 05:31 PM
Blower keeps cycling on and off simonb HVAC 1 01-17-2009 10:56 AM
