Installation Of Thermostat - HVAC - DIY Chatroom Home Improvement Forum
Old 10-07-2009, 11:36 AM   #1
Installation of thermostat
I am trying to reinstall an intertherm thermostat. ( Gas forced air heating with Air. I have four wires. 1 is labeled Y, 1 is labled R and 1 is labled W.
The last wire is not labeled, so I do not know where to connect it. My choices on the thermostat are O, B and G. The furnace is a three year old
Goodman.
fastcopy is offline   Reply With Quote
Old 10-07-2009, 05:58 PM   #2
Hvac Pro
yuri's Avatar
Rewards Points: 2,238
Look at the wires where they attach to the furnace circuit board and find where your lonesome wire goes. 99% sure it is for G. O and B are for heat pumps.
Old 10-07-2009, 06:13 PM   #3
biggles's Avatar
with power on the furnace and the stat off the subbase.take the mystery wire and touch the R terminal with the R wire connected,should bump the supply fan ......G Y is condenser,R is hot 24Vs,W is heat,G is fan
Old 10-08-2009, 05:09 PM   #4
Thermostat problems
Thanks for the help.
The problem turned out to be a broken G wire. I was broke inside the wall about 6 inches behind the thermostat. Unit is working fine now.
Thanks Again
Fastcopy
Installation of Honeywell Thermostat - cooling function KDW Electrical 0 10-04-2009 09:56 AM
Trane Z Wave Thermostat Installation TommyTelephone HVAC 1 09-13-2009 03:51 AM
help with installation of Honeywell RTH8500 thermostat dg xy HVAC 19 07-28-2009 12:25 PM
Bryant Evolution Thermostat: Installation & Programming NickE1963 HVAC 6 01-27-2009 03:57 PM
Thermostat Installation help helpless handyman HVAC 16 11-21-2006 08:31 PM
