Old 12-05-2009, 02:20 PM   #1
Installation of Furnace Humidifer
I'm about to install a Honeywell flow-through humidifer and have a two questions. 1) Does it matter whether it goes on the supply (warm) or return plenum. The instructions say suppy, but I've read others prefer it on the return; and 2) If I install on the suppy plenum, how much higher than the air conditioner coils should I go? I can maybe go a few inches, but that's all. Insight appreciated.
JF
bsmtreno is offline   Reply With Quote
Old 12-05-2009, 04:02 PM   #2
An old Tradesmen
Is it a bypass, or power humidifier.
Old 12-05-2009, 05:21 PM   #3
We put them on the return. Some day the drain line will plug and water spilling down the return is a whole lot better then water in the furnace.
Old 12-05-2009, 06:20 PM   #4
Hvac Pro
I put them on the return. If the plenum overheats it won't warp/melt the plastic housing. Continuous heat on the plastic eventually deteriorates them.
Old 12-06-2009, 10:48 AM   #5
It's a bypass - see link
http://www.homedepot.ca/webapp/wcs/s...owreviews=true
Old 12-06-2009, 10:51 AM   #6
An old Tradesmen
Makes no difference then(as far as humidifying your home). Since either way warm air will be blown through the pad.
It is safer on the return since as others said. lessens teh chance of water being dripped or pouring on your heat exchanger.
Tags
furnace, humidifier
New Furnace Installation otismyman HVAC 19 09-30-2009 11:27 AM
Problems with new furnace..Overheating, having to reset. Furnace too big? Tommy2 HVAC 41 12-01-2008 02:55 PM
New Cased Coil - Install to Furnace - PICTURES!! hartkem HVAC 39 11-18-2008 02:45 AM
Furnace Installation Cost philstewart HVAC 28 10-29-2008 08:22 PM
Central Air Installation vs. Oil Furnace shnfldr HVAC 6 06-20-2008 07:49 AM
