Install Water Mister By Outdoor Unit? - HVAC - Page 2 - DIY Chatroom Home Improvement Forum
Old 07-25-2011, 03:08 PM   #16
newtech's Avatar
Rewards Points: 164
Originally Posted by Artco View Post
Why would anyone want to add a mister if their system was maintained and designed correct!!!
Quote be the op....
Our outdoor unit is on the east side of the house and is shaded in the afternoon, but the whole area is concrete, not lawn, and stays pretty warm even at night. More-so with the latest heatwave crap...
newtech is offline   Reply With Quote
Old 07-25-2011, 03:27 PM   #17
newtech's Avatar
Rewards Points: 164
I don't think that this was to be a permanent fix. I think that it was just a temp fix with the heat we have been having.
Old 07-25-2011, 06:42 PM   #18
An old Tradesmen
Rewards Points: 7,776
Originally Posted by zootjeff View Post
I see they've added a water filter to their setups. Seems to me that if you have water soluble minerals, throwing a carbon filter at it isn't going to un-calcify and un-PH-ify your water. You can't all the sudden drink salt water because you run it through a carbon filter. Same thing here. You'd need a reverse osmosis or equiv..
Do you have any reason to believe their filter is actually going to condition water to remove minerals, or is it a marketing false advertising gimmick?
The filter will catch the non soluble items, but other then that, its just marketing.
Old 07-25-2011, 06:43 PM   #19
An old Tradesmen
Originally Posted by mar0isa View Post
How do geothermal units use open loop systems without calcifing the coil? Is it protected by something? What about cooling towers. Do they have calcification problems? I know if your system is sized properly, you shoulder need to do this but its interesting if it drops your register temp.
They don't evaporate the water. And even some of them do have troubles.
water heater drip kdange1 Plumbing 6 10-29-2014 05:26 PM
Water Inside/Around American Standard Furnace michrob HVAC 8 12-08-2011 03:51 PM
Help install Honeywell CM927 to Air to Water HeatPump Aermec ATC@LWSK HVAC 1 11-06-2010 05:54 AM
water borehole question joeuser General DIY Discussions 2 04-18-2010 10:33 PM
Is 1/2 Pex more restrictive than 1/2 copper? twilightcall Plumbing 19 06-24-2008 07:32 AM
