Old 10-16-2012, 12:02 PM   #1
Install Filter Rack at Return Air
I am selling my house and the buyer has requested for me to have a filter rack installed. How much should i budget for materials and installation?
matthewd is offline   Reply With Quote
Old 10-16-2012, 12:23 PM   #2
how
Usually a one to 1 1/2 hour job with pretty cheap materials. You need to be more carefull with a filter access cover on low & mid efficiency furnaces to prevent causing a local low pressure area near the furnace.
how is offline   Reply With Quote
Old 10-16-2012, 12:28 PM   #3
it is a newer furnace around 93% efficiency.
Do you have an estimate on cost based on your experience?
Old 10-16-2012, 01:01 PM   #4
raylo32's Avatar
For an idea, here is a typical pre-made filter rack. If you get the right one you can disconnect the existing return duct and put this in betwen it and the furnace. Tape it up and you're done...
http://www.alpinehomeair.com/viewpro...ctID=453058263
Live long and prosper.
raylo32 is offline   Reply With Quote
Tags
cost, filter rack, furnace, hvac help, install
Return Air Issues in old Pier and Beam House Hiker HVAC 0 10-01-2012 06:56 PM
Zone Dampers - Install on Both Supply and return? alecmcmahon HVAC 3 05-01-2011 05:33 AM
return air honola HVAC 11 08-13-2009 08:41 AM
Hog Hair Filter mjbxx HVAC 10 04-10-2009 09:46 AM
Bypass Humidifier goes before or after air filter? key1cc HVAC 9 12-30-2008 10:12 AM
