Install Fasco Inducer Model A242 - HVAC - DIY Chatroom Home Improvement Forum
Old 10-02-2007, 10:16 PM   #1
Unhappy
Hi Gang,
I need to install a Fasco Inducer on a high-efficiency Rheem furnace.
Funny story, the old one got rats in it during the summer. Thought they were only in the PVC exhaust and condensation pipe which I replaced. I discovered them because the house smelled terrible.
Anyway, some made it all the way into the inducer and died and rusted it out. I couldn't figure out why the furnace wouldn't turn on, so called a serviceman who found the second batch of rats.
The furnace is a Rheem Imperial 90 plus. Probably 20 years old.
The original inducer is a Fasco no. 7021-7150. I have a replacement - Fasco model #a242, 7021-11707.
I was a little surprised when I received the replacement. I thought the original had some low voltage wires connected to it that in turn connect to a panel on the front of the furnace. Indeed there are low voltage wires still on the furnace.
However, the replacement inducer does not have a place to connect the wires. There is only a ground wire and two power wires (black and white).
Any thoughts? I can send pictures if you think they can help..
morrelld97 is offline   Reply With Quote
Old 10-03-2007, 08:40 PM   #2
Rats ruined my inducer
No thoughts yet? OK, I have pics.
In one picture you will note that there is a small rubber tube that is disconnected. There is a small tube protrubing from the inducer that it seems logical to connect this to, however the tube is too narrow to fit over it.
There are also 2 red wires (with black electrical tape covering the ends) that should be connected to something. I know there is a panel next to the inducer with 2 connectors that should have some component attached to it.
There is a 3rd wire that is totally disconnected from anything hanging there as well. Any help appreciated.
Link to pics:
http://picasaweb.google.com/morrell....rFurnaceIssues
Last edited by morrelld97; 10-03-2007 at 09:00 PM. Reason: issue with getting pic attached
Inducer installation / modification ... caseywa HVAC 26 12-06-2010 02:50 PM
