Okay, last night noticed the inside air handler was running but the outside unit was not except for a hum coming from the unit and the top was hot. Turned the entire system off so it could cool off, I wasn't sure what the problem was.
This morning, turned the system on and the same issue. I gave the blades a tap on the outside unit a tap and they started turning. However, even after the unit has been running for about an hour there is still not cool air coming through the vents inside.
Intially I thought it was the motor or cap, which it still may be. However, now it seems like there is something else wrong also. Should I hear the compressor running if the motor is not running the fan still?
Any input is appreciated.
