Inside Or Outside Temp Fo P-T Chart - HVAC - DIY Chatroom Home Improvement Forum
Old 06-07-2009, 11:06 AM   #1
Rewards Points: 150
inside or outside temp fo P-T chart
I always thought when checking R-22 in a sytem the low side should read what ever temp it is on the inside the house, is that correct? When looking at the P/T chart for the high side reading, do you use inside or outside temp reading? Thanks for the help!
wetbar is offline   Reply With Quote
Old 06-07-2009, 01:06 PM   #2
An old Tradesmen
Rewards Points: 8,228
The vapor side should read what ever the appropriate temp is for the super heat required for teh current indoor wetbilb temp and outdoor drybulb temp if its a fixed meterng device.
If its a TXV, then it will read what temp its SH is set for, plus any line temp gain.
The liquid line should read the saturated condensing temp for the units efficiency.
At 75F an a 10 SEER unit, that may be 105F, or it could be 100F.
Not trying to be insulting.
You may want to get Modern refrigeration, and a few other books on vapor compression refrigeration operation.
Old 06-08-2009, 08:48 AM   #3
This article might be useful to you.
dac122 is offline   Reply With Quote
Old 06-21-2009, 02:15 PM   #4
Rewards Points: 150
OK That did help but I have one question- in the article is says to find superheat use the "Tmperature probe and a pressure/vacuum module in conjunction with a suitable digital multimeter with type K thermocouple measurement and a mV input."
Would the guages be used as the pressure/vacuum module? if not where can I get one on these? I have a multi meter that I think would work, but I am not sure what type K is.
Any help would be great!
Old 06-21-2009, 02:47 PM   #5
GC/Master Plumber/Mech
Rewards Points: 560
Basically a T/P chart only converts a pressure to a temp or a temp to a pressure.
For any given pressure the freon is a given temp or for a given temp the freon is a given temp.
Take a look at this article by Fieldpiece
http://www.fieldpiece.com/tech-artic...bleshooter.htm
Old 06-21-2009, 03:59 PM   #6
An old Tradesmen
Yes, the gauges are the pressure vacuum module.
Heres a site with some probes yoou could use.
http://www.allproducts.com/search/se...couple%20probe
sealing INSIDE an exterior wall penatration measure thrice Electrical 1 01-24-2009 02:12 PM
Best High Temp Paint for wood stove?? Sellncars Painting 9 01-21-2009 06:21 PM
Some walls rattle in my house if hit with something, I will explain inside posting zincmann Building & Construction 4 11-10-2008 03:05 PM
new ( to me ) house... cold inside, warm outside... what's the deal? MrLinux General DIY Discussions 7 02-13-2008 08:33 PM
