Inflow Duct Blowing Outward Instead Of Inward - HVAC - DIY Chatroom Home Improvement Forum
Old 12-27-2012, 03:23 PM   #1
inflow duct blowing outward instead of inward
The inflow duct of my forced-air furnace seems to be blowing outward instead of inward.
What are the most likely causes ?
After the hurricane I had to change the electronic igniter since it got wet.
Could water damage be the cause of this problem ?
Ive heard I should check the dampers.
What are they and how do you check them ?
goldenboyblue is offline   Reply With Quote
Old 12-27-2012, 04:19 PM   #2
An old Tradesmen
Rewards Points: 6,916
Did the gas vale also get wet? If so it also needs replaced.
Water may have damaged the motors windings, or the run capacitor.
Duct Sizing Confusion dw8468 HVAC 4 11-02-2012 09:25 PM
?an Insulated Flexible Duct - half attached and half unattached ? tran Roofing/Siding 2 06-21-2012 06:25 PM
Planning on New duct work..any feedback... kilosos2 HVAC 28 01-26-2011 09:21 AM
Metal duct or flex? smokey982 HVAC 6 08-06-2010 06:20 AM
Condensation in Wall: Can I Seal a Dryer Duct With Caulk? xquercus HVAC 5 07-01-2007 02:33 PM
