Infinty 19 Hybrid System-Furnace Lockout - HVAC - DIY Chatroom Home Improvement Forum
Old 11-02-2010, 01:10 PM   #1
Question
Infinty 19 Hybrid System-Furnace lockout
My hybrid Carrier Infinty 19 system HP and gas furnace is controlled by Infinity Control Thermostat. The HP lockout is set at less than 35 degrees and the furnace (auxilary) at more than 50. This morning the sysetm was recovering from 63 to 69 degrees, The outdoor temp was 34. The furnace ran and continued to run even when the outdoor temp reached 43 degrees. The targeted temp of 69 had been reached. The furnace finally shut off. The HP did not kick in. I tested the HP and it ran properly. I thought the HP would begin to run above the less than 35 HP lockout temp? Can anyone help me?
aonorat is offline   Reply With Quote
Old 11-02-2010, 08:34 PM   #2
An old Tradesmen
Rewards Points: 6,566
Last I knew. The furnace runs until the heat call is over. Even if the outdoor temp rises above lockout during the heat call.
Old 11-02-2010, 11:31 PM   #3
Thanks for the reply. I kind off thought that was the case but the dealer that installed the system did not fully understand. Carrier operational manuals and dealers need to do a better job of explaining these systems so users can understand these functions. Thanks again.
Old 11-03-2010, 05:19 AM   #4
An old Tradesmen
Training from most brands is variable by the trainers own understanding or lack of.
Old 11-03-2010, 12:14 PM   #5
Thanks for your help!
Carrier Furnace: Gas Heating Lockout kkf HVAC 20 02-17-2017 06:55 PM
Oil fired furnace and hot water heater question steveinpa Plumbing 3 08-10-2010 09:42 AM
Bryant - sporadic lockout ernie6767 HVAC 3 12-18-2009 07:19 PM
backflow in oil/wood system jmancine HVAC 8 10-30-2007 03:17 PM
Replace furnace, coil and duct system sps123 HVAC 2 01-07-2006 11:56 AM
