Infinity System Trouble - HVAC - DIY Chatroom Home Improvement Forum
Old 09-24-2008, 04:15 PM   #1
Infinity System trouble
Hi, Help!!
I have an Carrier Infinity 58CVA110 Furnace and I just installed a Carrier Infinity thermostat SYSTXCCUID01-B. All instalation was as per exact carrier instructions. Now it seems my variable speed fan only runs at the same RPM regardless of being on low/hi burner. The burner still starts on low then ramps up to hi fire as required but my blower motor stays at same speed. I had a Honeywell Vision Pro on it prior and you could hear the blower speed up when furnace switched to hi fire. I ran check system on thermostat it runs low/hi fire properly, no fault codes and no signs of problems. I can manually set the fan speed with the low/med/hi on thermostat with no issiues but I leave it on auto. Can anybody help me out! Also my static pressure is around .75 is that to high?
DJD
djd2008 is offline   Reply With Quote
Old 09-24-2008, 04:50 PM   #2
1610 CUB's Avatar
Rewards Points: 150
How did you obtain "static pressure is around .75" ?
1610 CUB is offline   Reply With Quote
Old 09-24-2008, 06:54 PM   #3
the thersstat has a test for it,,,,
Any other help guys, anyone installed and infinty thermostat?
HELP....djd
The New infinity thermostat gives you such diagnostics and more!
Hot Water Heating System in older house GrannyAnnie HVAC 2 08-31-2008 04:50 AM
New House, new system, poor cooling Faulknertw HVAC 15 07-08-2008 10:06 PM
Is 1/2 Pex more restrictive than 1/2 copper? twilightcall Plumbing 19 06-24-2008 07:32 AM
Carrier Infinity T-stat and Performance heat pump gcole HVAC 3 10-03-2007 03:00 PM
