Induction Fan Constantly Running - HVAC - DIY Chatroom Home Improvement Forum
Old 08-07-2011, 12:41 PM   #1
induction fan constantly running
Our furnace with central air has been making noise. I have had a service man look at it, and of course no noise made while he was here. He came out a second time and it was determined that it was the induction fan that was running and making the noise( he also told us that the induction fan should only come on with the furnace). Will this constant running running of the inducation fan damage the motor and eventualy the furnace? I can't afford a new one. Please help!!!!!!
sue1 is offline   Reply With Quote
Old 08-07-2011, 12:46 PM   #2
Hvac Pro
yuri's Avatar
Rewards Points: 2,282
Yes. If you have a cheap power stealing electronic thermostat it can activate the induction fan relay. Or you may have a faulty circuit board. Should get it repaired as the fan will wear out and that is another cost to you. Post a closeup pic of your thermostat and we may able to tell you if it is a problem one
Old 08-07-2011, 12:54 PM   #3
Experienced
Jackofall1's Avatar
At a minimum, as you are not using the furnace you should find or have the service tech find the power source to the induction fan and disconnect it, at least that way you will save the fan and motor.
Just remember in order to have heat you need that fan.
Mark
Old 08-07-2011, 04:13 PM   #4
An old Tradesmen
Rewards Points: 7,372
Is the furnace in the attic?
Old 08-09-2011, 10:58 PM   #5
hehe, well hehe, if it is the induction fan (a.k.a. blower motor) making the noise, i think it time to get it changed out for another one already. whether you want it to or not i think its about to give out completely.
and yes it will damage ur compressor when the thing eventually gives...
costing u more $$$
Final Notice is offline   Reply With Quote
Help with drainaige - Sump constantly running TANC Landscaping & Lawn Care 20 04-03-2010 11:15 PM
Heat and Condenser running at same time emmark22 HVAC 2 01-12-2010 12:28 AM
constant running water sound gmk2008 Plumbing 9 11-11-2008 08:22 PM
furnace blower constantly running HELP! ice_wolf69 HVAC 16 10-26-2008 06:11 PM
taco 700 constantly running.... drizzyboy HVAC 3 11-27-2007 07:03 AM
