-   -   Induction blower seal (http://www.diychatroom.com/f17/induction-blower-seal-6905/)
ktritz 03-05-2007 05:55 PM
Greetings!
I just replaced the induction blower on my Trane x80 furnace. The seal between the former blower and the furnace was a very fibrous gasket that essentially disintegrated when I took it out.
I replaced the blower with a Fasco A143, but it didn't come with a gasket or seal. I've seen suggestions of using a bead of silicone around the blower...
How essential is this gasket? Is this something that needs to be fixed ASAP, or can I put it off until the weekend?
Are there any suggestions as to what type of gasket or silicone to use to seal the blower?
Thanks!
Kevin
harleyrider 03-05-2007 06:34 PM
Use High temp RTV (like what you would use on a automotive valve cover back in the day) and DO IT TODAY! a 1/2 in bead will be fine.
ktritz 03-05-2007 06:46 PM
Thanks for the suggestion. Do they have the high temperature stuff at Home Depot/Lowes?
Presumably, this http://www.google.com/search?q=loc37469 is the stuff you're talking about...
Kevin
elementx440 03-05-2007 08:33 PM
an autoparts store will have high temp rtv as well, like an autozone or napa.
harleyrider 03-05-2007 09:52 PM
Kevin
Yep thats it...........
