Inducer Motors On Bryant 350AAV - HVAC - DIY Chatroom Home Improvement Forum
Old 02-17-2007, 11:42 AM   #1
Inducer motors on Bryant 350AAV
In the last two months Ive had 3 inducer motors go bad on 3 Bryant 90% furnaces. I was wondering if there is something I'm not doing right in the install, or if its a fluke thing. I'm leaning towards it being something im doing or not doing during the install. Any help from you Carrier people would be great.
RookieTinner
Rookietinner is offline   Reply With Quote
Old 02-18-2007, 03:38 PM   #2
Thoroughbred Mopar Man
Rewards Points: 502
Hi Rookietinner
If the 90 plus Carrier, Bryant, or Payne inducers have any vibration in them when you start it up. The inducer assy needs to be sent back and not used. I had several of them come from the factory with the inducer wheels fractured from what I assumed was dropping them. Not sure thats what caused damage but it was odd this many had the same problem. Check your lot numbers and see if they are sequential. If they are demand a inquiry, its your reputation when you have repeated call backs. The only other thing is you could have a restricted secondary heat exchanger. This will cause overstressing of the inducer wheel and cause pre mature failure also. Take your magnhelic readings, if you are above 2" wc you are ok. If you are below that, clean the heat exchanger.
Good luck
Rusty
Character is doing the right thing even when no one is looking. Intelligence is understanding and practicing the meaning of character.
#CARRIERMAN is offline   Reply With Quote
Inducer installation / modification ... caseywa HVAC 26 12-06-2010 01:50 PM
Another Bryant 383KVA with code 31 problems rpgIVguru HVAC 1 02-05-2007 01:47 PM
bryant furnace will not light somany?'s HVAC 16 11-29-2006 08:28 PM
Replacement Inducer Blower caseywa HVAC 18 11-27-2006 03:42 PM
Bryant Inducer Fan Runs Constantly biglittledan HVAC 4 11-24-2006 11:23 AM
