Inducer Motor Pulsating Sound? - HVAC - DIY Chatroom Home Improvement Forum
Old 12-22-2011, 04:26 PM   #1
MikeKy55's Avatar
Rewards Points: 254
Inducer motor pulsating sound?
I have a Bryant 90 plus furnace. Over the last few weeks I have started hearing a pulsating sound when the inducer motor starts and runs. If need be, I can go down and get the model number. The unit is about 9 years old.
Thanks in advance
'It's never too late to say ''THANK YOU'' to a veteran of our armed services'
MikeKy55 is offline   Reply With Quote
Old 12-22-2011, 04:38 PM   #2
I have seen this many many times, as long as the amp draw is not above what the motor rating is, and the noise doesn't keep you up at night, the motor may run another 10 years like that
harleyrider is offline   Reply With Quote
The Following User Says Thank You to harleyrider For This Useful Post:
MikeKy55 (12-22-2011)
Old 12-22-2011, 08:43 PM   #3
HVAC Tech/ Browns Fan
It may have water building up inside of it and not drain all the away out
Tator1076 is offline   Reply With Quote
The Following User Says Thank You to Tator1076 For This Useful Post:
Inducer installation / modification ... caseywa HVAC 26 12-06-2010 02:50 PM
Why is Inducer Fan Running? artbuc HVAC 3 07-31-2010 10:39 AM
Pressure Switch, Draft Inducer, Burner Box, Problem majorapus HVAC 7 10-25-2009 07:14 PM
Soundproof Windows BlueJello General DIY Discussions 3 11-30-2007 06:34 PM
What makes a quiet window? Badfish740 Building & Construction 8 09-30-2007 11:22 AM
