Inducer Motor Problem AGAIN!!! - HVAC - DIY Chatroom Home Improvement Forum
Old 02-23-2013, 01:33 PM   #1
Inducer motor problem AGAIN!!!
Inducer motor not creating enough vacuum on a john woods 40 gal powervent hot water heater. Tank is 4 years old, replaced first blower 2 years ago, at that time measured 2" WC with no flue, 0.6" with flue. Pressure switch is rated at 0.15 " WC. Now measuring 0.2 " with no flue, .05 with flue. 13 ' of 2" venting with 3 90 deg. elbows. Have replaced 2 of them with 45's, not much change. Cleaned fins on the motor, still no help Short of replacing yet another inducer motor, any ideas? Next tank is going to be a direct vent!!
tlukwin is offline   Reply With Quote
Old 02-23-2013, 02:02 PM   #2
Rewards Points: 34
Do you have the installation manual? You might need to upside your exhaust pipe to 3 inch.
djlandkpl is offline   Reply With Quote
Old 02-23-2013, 06:10 PM   #3
as seen on tv
Rewards Points: 150
internal blockage inside tank?
qbert is offline   Reply With Quote
Old 03-03-2013, 11:04 AM   #4
2 " venting is theoretically good for 50', I have an equivalent run of 17'. Plus it was working initially with the same piping. As for internal. GSW is no help, they dont answer emails, Anyone?? Next tank I buy will not be a power vent, and definitely not a John Woods.
Old 03-03-2013, 11:08 AM   #5
How would a blockage inside the tank have anything to do with the venting. It draws air from baffle, and works again when the fan is changed?
Old 03-03-2013, 12:04 PM   #6
Hvac Pro
yuri's Avatar
Rewards Points: 2,260
It could be the baffle inside the tank is carbonned or rusted up and blocking the space the flue gas has to exit. THe inducer/exhaust fan has to suck thru the tank so internal blockage is possible. Also possible they have a bad batch of exhaust fans. I have not removed the top of one of those to see if it has a removable baffle like the old natural draft one has. Also some tanks had a screen underneath them where the combustion air enters and they plug easily with dust/dirt/dog hair. Wherever the air enters the burner is where you want to look and different brands do it differently. May need to take a inspection mirror or mirror and look under the tank for that screen.
Old 03-03-2013, 01:23 PM   #7
Roofmaster
Rewards Points: 2,210
Maybe your air intake at the bottom of the tank is blocked with sawdust or something?
Power vent water heaters usually have 3 inch PVC pipes in my experience. I think you should change to 3 inch considering how much drop you get when adding your flue.
Old 03-04-2013, 07:36 PM   #8
Replaced blower motor today, heater works again. Vacuum pressure still seems suspiciously low, 0.2", will take a look at the air intake and baffle when I get a chance and report back.
Old 03-05-2013, 12:49 PM   #9
hvac5646 is offline   Reply With Quote
Insufficient flow from exhaust inducer - won't actuate pressure switch FunWithTools HVAC 30 11-04-2012 07:10 PM
Inducer Fan Not Turning On Deemar HVAC 79 10-22-2011 12:05 AM
Inducer installation / modification ... caseywa HVAC 26 12-06-2010 01:50 PM
Why is Inducer Fan Running? artbuc HVAC 3 07-31-2010 09:39 AM
Pressure Switch, Draft Inducer, Burner Box, Problem majorapus HVAC 7 10-25-2009 06:14 PM
