Inducer Motor On/off - HVAC - DIY Chatroom Home Improvement Forum
Old 03-18-2009, 08:54 AM   #1
inducer motor on/off
Hey guys,
I have a goodman GMP125-5 heater that has been acting weird for sometime. Here is the problem, when I turn on the thermostat the induction motor comes on and off. It will stay on for a sec or two then turns off but eventually after several tries the induction motor starts working fine and the whole heater starts. After that it works fine. By the way this is a new induction motor that was installed about a year ago so i doubt its the motor itself. I am a newbie to this community and I'm not sure of all the termonology that you guys use so please dummy it down for me. I will try to upload a video on youtube sometime soon so you can get a better idea of what the problem might be. Thanks for all you help!!
drummerprince is offline   Reply With Quote
Old 03-18-2009, 08:58 AM   #2
Hvac Pro
yuri's Avatar
Rewards Points: 1,818
If you have a constant 24 volts from W to C at the circuit board when this is happening then the inducer fan relay/board are faulty. Looks like a new board is needed.
Old 03-18-2009, 01:20 PM   #3
I looked on the circuit board and I was able to find where W was but I cant find C. I noticed that they have W, G and R but not C. Could C have been renamed by one of these?
Old 03-18-2009, 01:36 PM   #4
Hvac Pro
yuri's Avatar
No. Some Goodmans were cheap and did not have proper wiring terminals on the board. The connections were done in midair from the transformer with splices/marrettes. The reason I said check the voltage is if your thermostat is faulty and fluttering it may be the problem. 99.5% of the time it is the circuit board.
Old 03-18-2009, 02:10 PM   #5
Hey Yuri! Thanks for helping me out. I think you are right, its the circuit board. When I was listen to the heater I noticed a clicking sound and I narrowed it down to the circuit board. I'm sure its not operating right so I'm gonna go out and buy another one. I will let you know what happens afterward.
Old 03-18-2009, 04:19 PM   #6
First make sure there is not some root cause that makes the circuit board fail.
Inducer installation / modification ... caseywa HVAC 26 12-06-2010 01:50 PM
Carrier Model 58MVP inducer motor deanray HVAC 11 11-19-2010 04:33 PM
Inducer motor or control circuit? Please help me troubleshoot. averagerob HVAC 1 03-03-2009 01:43 PM
Heil furnace inducer vibrating, capcitor handling question diggerdave HVAC 45 03-01-2009 04:56 PM
Inducer fan assembly or inducer control circuit board failing realblonde94526 HVAC 3 05-12-2008 07:28 PM
