Inducer Motor Not Drawing Enough Vacuum For Switch? HELP! - HVAC - DIY Chatroom Home Improvement Forum
Old 10-13-2011, 10:30 PM   #1
Inducer Motor not drawing enough vacuum for switch? HELP!
Kind of at my wits end here...
I have a Goodman GMNT080B. The inducer sits on the front, bolted to the flue pan. It's high efficiency so from there it goes out via a PVC tube to the outside.
Last season the shaft in the inducer motor got excessive play in the bearings. So this month I brought it to an electrical motor rebuild place, and they put fresh bearings in it. Spins great, no sounds, no issues, no problems.
I go to reinstall it, and realize that there was a gasket between the inducer and the flue pan, which is now mostly gone/damaged. So I cleaned up both surfaces, scuffed them lightly, and put a bead of red hi-temp silicone around it, and threw it back together. I confirmed that, go figure, Goodman refuses to sell JUST the gasket, only the entire $400 motor.
The furnace won't start. I get 3 flashes on the LED on the control board, which indicates a problem with the pressure switch, according to the little chart on the furnace.
I ran a snake through the exhaust tube, confirmed there's nothing blocking it.
I re-did my silicone seal just in case maybe some air was getting sucked in there.
I also confirmed the pressure switch is still functioning, by sucking on the little vacuum hose, I hear a "click."
The plot thickens though, because without fail, if I pop the exhaust pipe off the inducer motor and switch on the furnace for a moment (just long enough to confirm it works, BEFORE it starts pumping carbon monoxide!), everything works perfectly.
So again, I know there's no blockage in the PVC pipe, and it worked for the 5 years we've lived here through that pipe.
The only thing left I can think of, and I'm going to call them tomorrow, is that something went wrong with the motor rebuild, and now the thing spins, but doesn't have ENOUGH power to trip the pressure switch? That would explain why removing all the exhaust frees up the backpressure and the motor can trigger the switch.
Thoughts anyone? Winter is coming!
tigeraid is offline   Reply With Quote
Old 10-13-2011, 11:23 PM   #2
JJboy's Avatar
Inducer motor works with high rpm....you should check it
**Always kill the power ** Hot air rises, but heat will always move from higher to lower temperatures. ** Real man shoot in manual. ** If it ain't grounded, it ain't dead.
JJboy is offline   Reply With Quote
Old 10-14-2011, 08:54 AM   #3
Is the motor rotation correct? Maybe the the fan blades were installed backward, or something was reinstalled backward when rebuilt causing reverse rotation.
thestig3 is offline   Reply With Quote
Old 10-14-2011, 02:42 PM   #4
It's not backwards. But yeah, I called the rebuilder this morning and he's going to take another look at the motor... the only thing he can think of is, he installed shaft/bearing "down" slightly further into the body of the blower than it was, because the fan looked like it was rubbing a little... But that in term would've moved the blower cage around inside and it might not be making enough suction.
Old 10-14-2011, 04:30 PM   #5
Rewards Points: 460
ID fans are sensitive.
I recommend looking here to match up:
http://www.fasco.com/documents/pgs068-095.pdf
http://www.fasco.com/documents/pgs051-059.pdf
Then order someplace like here
http://www.cshincorporated.com
Not sure gaskets are sold there. If you want to change just the blower wheel, see if your broken one has part # 8710-4358 stamped on back. If so, that's the SKU # at CSH Incorporated. When I ordered in September 2010, part was $23.34 plus $7.80 to ship. 989-723-8985
diyorpay is offline   Reply With Quote
Old 10-14-2011, 05:24 PM   #6
biggles's Avatar
the PS has only one tube port to go to the discharge section of the ID fan housing with that tube againg the pressure switch is to close to proof the air being injected into the burner and start the burner cycle
Old 10-15-2011, 11:37 PM   #7
Er... Sorry man, you lost me there. Could you reword that?
Old 10-16-2011, 08:27 AM   #8
biggles's Avatar
sorry about ......that, simply the PS is closing from the air pressure from the ID the switch doesn't control the ID
Old 10-16-2011, 04:57 PM   #9
I didn't say it did?
I said when the inducer comes on, it DOESN'T trip the pressure switch. If I suck on the hose, the switch trips, and everything works. So the inducer isn't generating enough pressure/vacuum to trip the switch.
Old 10-16-2011, 07:34 PM   #10
An old Tradesmen
Rewards Points: 6,090
Is the restrictor plate missing. Some units need one, some don't.
Old 10-16-2011, 07:50 PM   #11
Yes, the restrictor's in place. It was originally there, too.
Old 10-16-2011, 10:59 PM   #12
The furnace appears to be working fine now, at least for the last four tries... I suck-started it once myself, quickly replacing the hose and letting it warm up the house (it was damn cold.) Since then it appears to work normally.
I do notice the condensation trap is making a bit of a gurgling noise... is that normal?
EDIT: actually now that I think about it, if that venter motor still wasn't sucking at full capacity, it would cause more moisture buildup in the flue than normal, right? .... Guess I should take it back to the rebuilder. :/
Old 10-17-2011, 05:19 AM   #13
An old Tradesmen
On some units, an empty tap will cause the inducer to not be able to close the switch.
Old 10-18-2011, 03:33 PM   #14
Alright, it's been a whole day without any problems, so I think it's fixed. The motor rebuilder moved the blower cage "down" a bit inside the housing, closer toward the vacuum side, thinking that might do the trick. So far everything's working great, and I don't hear any gurgling from the condensate pump either.
Here's hoping.
Inducer Fan Not Turning On Deemar HVAC 79 10-22-2011 01:05 AM
Inducer installation / modification ... caseywa HVAC 26 12-06-2010 02:50 PM
Why is Inducer Fan Running? artbuc HVAC 3 07-31-2010 10:39 AM
Inducer Vacuum Problem RobertCan HVAC 21 12-22-2009 04:20 PM
Pressure Switch, Draft Inducer, Burner Box, Problem majorapus HVAC 7 10-25-2009 07:14 PM
