Inducer Motor Keeps Running-no Heat - HVAC - DIY Chatroom Home Improvement Forum
Old 03-24-2009, 10:27 AM   #1
inducer motor keeps running-no heat
I have a upflow Amanda gas heater,whwen I turn on the stat the in inducer turns on tou can hear a couple of faint clicks and a faint smell of gas. but nothing other than the inducer just keeps running? any ideas?
zombie911 is offline   Reply With Quote
Old 03-24-2009, 12:26 PM   #2
check the silicone ignitor, might be cracked or broke
wudtick1 is offline   Reply With Quote
Old 03-24-2009, 02:16 PM   #3
HVAC / Plumbing
how old is the unit ?? Check all roll out switches (if you have them ). There is a small re set button in the middle.. If it's opening the gv & allowing gas to the burners...it's probably bad ignitor
kenmac is offline   Reply With Quote
Help..Emergency Heat Running All the Time KatieB HVAC 4 02-25-2009 04:55 AM
Aux heat always running and high energy bills BurningMad1 HVAC 1 02-07-2009 04:50 AM
How to test apartment Heat Pump tbrubes HVAC 7 02-04-2009 03:05 PM
Heat Pump Woes Zenica HVAC 50 01-27-2009 07:37 AM
