Inducer Motor; ID On Part: Carrier Part # HC21ZE123A - Cross Reference Help - HVAC - DIY Chatroom Home Improvement Forum
Old 03-02-2008, 10:36 PM   #1
Inducer motor; ID on Part: Carrier Part # HC21ZE123A - Cross reference help
I have a Bryant Plus 80 Gas Furnace; Model # 311AAV048110AAJA (installed 2002)
I need the Inducer motor; ID on Part: Carrier Part # HC21ZE123A
115 V, 60Hz, 1PL
1.7FLA 30MPH 3000RPM
T.P.L Class B CONT DUTY
(Jakel Inc J238-150-15215)
I was hearing a kind of a strange fan noise, I thought it was the blower fan again ( had it replaced in 2005). Two days later the heater shut down, and finally I figured out that it's the draft inducer motor. I pulled it out and gave power direct, it spins for a few seconds and then stops and starts growling. This is how I troubleshooted, am I correct?
How can I cross reference this motor, I called Grainger and gave all the above info and they could not id the motor.
Thank you.
mtom01 is offline   Reply With Quote
Old 03-03-2008, 06:36 AM   #2
biggles's Avatar
search this site for exact motor http://bestbuyheatingandairconditioning.com/index.htm put part # in search and then again into parts locator for motors on next page coming up.
Old 03-16-2009, 08:27 AM   #3
Sounds like the motor is at its end. If there is nothing binding the motor or fan assembly, it is probably a defective bearing.
billmc is offline   Reply With Quote
Old 03-16-2009, 08:59 AM   #4
With the 115v, 1.7 full load amps, 3000 rpm, and knowing the direction of rotation and shaft size you could use almost any motor that meets these specs.
I don't know what the 30 MPH means.
Yeah, bearings are shot. In a pinch I guess you could have the motor rebuilt.
Old 03-16-2009, 09:41 AM   #5
that's the motor's speed limit of course
hvaclover is offline   Reply With Quote
Old 03-16-2009, 09:44 AM   #6
MOT21ZE123 Carrier, Bryant, Payne OEM Factory Direct Replacement Inducer Motor. $149.96
Old 03-16-2009, 02:54 PM   #7
Hvac Pro
yuri's Avatar
Rewards Points: 2,262
Ya better order the blower wheel that goes with it. They warp VERY EASILY and seize on. Had to saw one off the other day. And a tube of red RTV silicone to seal the housing.
Old 03-16-2009, 05:34 PM   #8
You might get a better price from these guys
http://www.google.com/search?client=...UTF-8&oe=UTF-8
Old 05-18-2010, 06:20 PM   #9
Hey all, and nice to meet ya.
had the exact same problem as mtom01, and this thread helped me out a lot, so thank you all.
Last edited by Scuba_Dave; 05-18-2010 at 06:34 PM. Reason: removed advertising links
Tooele is offline   Reply With Quote
Old 05-19-2010, 02:40 AM   #10
Your welcome.
Now write us a check for our time.
Old 02-20-2011, 06:43 PM   #11
The problem is not the motor. It is the cheap bearings on both ends of the shaft. I fixed mine by pulling them off with a gear/bearing puller. Then I greased them and reversed them on both ends of the shaft.
Worked like a charm.
Onepingonly is offline   Reply With Quote
Carrier air handler blower part pwrengineer HVAC 8 04-16-2011 12:42 PM
Inducer Part Needed: Please Help! BDPNA HVAC 55 12-08-2010 08:48 AM
