Is This An Inducer Motor? How To Test Circuit? - HVAC - DIY Chatroom Home Improvement Forum
Old 12-07-2015, 03:16 AM   #1
Rewards Points: 18
Is this an Inducer Motor? How to test circuit?
Hello!
First, I really appreciate you taking the time to read this.
Second, I am in need of some help with identifying parts and how to go about safely testing them. I'm not very familiar with HVAC but I wanted to post here to make sure I don't do anything potentially dangerous.
Here's the problem. The unit is a Carrier 48SS.
It has an intermittent issue with the heater.
about once a day the unit will kick on to heat the house, but after the cycle is finished the blower motor for the house will shut off but the unit itself keeps running.
I think this is the Inducer Motor not shutting off, and since it keeps running it keeps the unit from turning on again even though the thermostat drops below the set temp range. The only way to get it working again is to cut power to the unit. I'm not familiar with HVAC enough to know if this is the right name for the part.
I have tried cutting power for 10 minutes, checked the status LED for a blinking code (no code, stays on solid), and inspected for any obviously burnt out components on the board.
I'm not familiar enough with the board layout to know what the component tolerances should be. I have a multimeter and an o-scope at home and am familiar with them should there be some test I could do to check correct functionality.
I have included a picture of the motor in question. This is an outdoor unit so it's a bit dirty. I have vacuumed out the components some (with the breaker off) in hopes that it would remove any possible short.
I hope this isn't too rambling but I would hate to leave out an important bit of information.
Thanks for any and all help!
Bill
cannibal is offline   Reply With Quote
Old 12-07-2015, 04:02 AM   #2
An old Tradesmen
Rewards Points: 8,168
Probably the inducer relay on the board sticking shut.
Old 12-07-2015, 04:50 AM   #3
Rewards Points: 18
Thanks!
I'll see about testing the relay. I'm working right now but I'll pull the board when I get a chance.
I'll see if I can track down that relay on mouser or digikey and swap it out if the relay is bad.
After taking a closer look at the picture I'm seeing some discoloration on the board just above the two wight resistors and at R1. Could this be indicative of other issues with the unit?
Old 12-07-2015, 05:20 AM   #4
Rewards Points: 3,952
Does it physically keep firing after the blower shuts down, or does the burner shut down but the inducer stays running?
roughneck is online now   Reply With Quote
Old 12-07-2015, 05:31 AM   #5
Rewards Points: 18
The burner shuts down but the inducer stays running.
The unit will never cycle back on either, even with a call to heat. The only way I can get the inducer motor to stop and get the unit functional again is to interrupt power at the circuit breaker.
Old 12-07-2015, 06:28 AM   #6
Rewards Points: 1,720
There are no cold weather issues with an outdoor unit like this one, or is that because this one's in a warm climate?
Thx, Ducky
justplumducky is offline   Reply With Quote
Old 12-07-2015, 06:32 AM   #7
Rewards Points: 18
They're supposed to be ok outside regardless, according to carrier who I trust about as far as I could throw one of these units. At any rate, I'm in San Diego so cold weather issues are unlikely.
The Following User Says Thank You to cannibal For This Useful Post:
justplumducky (12-07-2015)
Circuit Breaker Troubleshooting Question - need help! DanLeonard Electrical 4 10-01-2012 11:20 PM
Tripping breakers,neutrals,120 volts and 240 volts OH My!!! Stubbie Electrical 17 06-11-2011 06:09 AM
Pressure Switch, Draft Inducer, Burner Box, Problem majorapus HVAC 7 10-25-2009 06:14 PM
Just for fun Andy in ATL Electrical 56 10-20-2009 09:33 AM
Help! Circuit breakers in trouble Circuit breakers Electrical 9 12-22-2008 12:58 PM
