Inducer Motor Had Been Squeaking - HVAC - DIY Chatroom Home Improvement Forum
Old 12-17-2009, 08:19 PM   #1
Question
Inducer motor had been squeaking
HI, I have a Day & Night 350MAV048100ACKA furnace that is on the blink.
It does nothing when I run through the test cycle and then flashes an 11. The inducer motor has been making funny noises for the last week or so every time it started up. When I start the test cycle, the inducer motor hums a little but won't turn the fan. Do you think it is a bad inducer motor, or could it be something else???
OhDamn is offline   Reply With Quote
Old 12-17-2009, 08:59 PM   #2
Hvac Pro
yuri's Avatar
Rewards Points: 92
Sometimes the impeller fan hits the housing inside and breaks and it sounds like you need a whole new fan unit. I have replaced lots of them. They get off balance and break, not uncommon. If it is a mid efficiency furnace with a metal pipe to the chimney, remove it at the top of the furnace and look for a dead bird inside the fan, no joke, it happens.
Old 12-17-2009, 09:11 PM   #3
Thumbs up
Thanks, Yuri
Thanks for the quick reply. It's called a "Plus 90" furnace with a plastic pipe to the outside. I'll pull it off to see if there is something in the inducer fan cage. - Jim
Old 12-17-2009, 09:15 PM   #4
Hvac Pro
yuri's Avatar
Rewards Points: 92
Not an easy unit to remove and reinstall. Need red rtv silicone to seal it back up and it is VERY easy to pinch the vacuum hoses and break the silly accordian drain hoses. You need a whole inducer fan, does not come as seperate motor and fan.
Old 12-17-2009, 09:18 PM   #5
Good to know!
That's good to know! I'll have to drop over to the wholesaler tomorrow to get some red silicon. By the way, I love your picture! It reminds me of our Chairman of the Board!
Old 12-17-2009, 09:19 PM   #6
Hvac Pro
yuri's Avatar
Rewards Points: 92
Yah, I shoulda been born rich instead of handsome!
Tags
code 11 , inducer won't run , test cycle fails
Inducer installation / modification ... caseywa HVAC 26 12-06-2010 01:50 PM
Pressure Switch, Draft Inducer, Burner Box, Problem majorapus HVAC 7 10-25-2009 06:14 PM
Inducer assembly cracks and replacement/repair DIYNew HVAC 3 10-23-2009 01:55 PM
Heil furnace inducer vibrating, capcitor handling question diggerdave HVAC 45 03-01-2009 04:56 PM
Inducer fan assembly or inducer control circuit board failing realblonde94526 HVAC 3 05-12-2008 07:28 PM
