Inducer Motor Getting Hot - HVAC - DIY Chatroom Home Improvement Forum
Old 11-17-2012, 01:39 AM   #1
inducer motor getting hot
i have a york furnace, recently i changed the inducer motor with the same type it had before. The new motor casing and shaft end gets hot while the furnace is running (not easy to touch). coluld any one help why its happening.
thanks
kulwinder is offline   Reply With Quote
Old 11-17-2012, 08:22 AM   #2
Rewards Points: 460
Did you match exactly?
http://www.fasco.com/documents/pgs022-030.pdf
diyorpay is offline   Reply With Quote
Old 11-17-2012, 09:43 AM   #3
inducer motor do run hot ,check the amp draw on it
mrairflow is offline   Reply With Quote
Old 11-17-2012, 11:46 PM   #4
Because it is directly in the combustion gas stream
most people cannot go grab a flue pipe and be happy.
Chimmy is offline   Reply With Quote
Inducer Fan Not Turning On Deemar HVAC 79 10-22-2011 01:05 AM
Inducer installation / modification ... caseywa HVAC 26 12-06-2010 02:50 PM
Why is Inducer Fan Running? artbuc HVAC 3 07-31-2010 10:39 AM
New pressure switch and inducer and still incorrect drafting kevintabb HVAC 5 01-19-2010 01:59 PM
Pressure Switch, Draft Inducer, Burner Box, Problem majorapus HVAC 7 10-25-2009 07:14 PM
