-   -   inducer motor getting hot (http://www.diychatroom.com/f17/inducer-motor-getting-hot-163603/)
kulwinder 11-17-2012 12:39 AM
i have a york furnace, recently i changed the inducer motor with the same type it had before. The new motor casing and shaft end gets hot while the furnace is running (not easy to touch). coluld any one help why its happening.
thanks
diyorpay 11-17-2012 07:22 AM
Did you match exactly?
http://www.fasco.com/documents/pgs022-030.pdf
mrairflow 11-17-2012 08:43 AM
inducer motor do run hot ,check the amp draw on it
Chimmy 11-17-2012 10:46 PM
Because it is directly in the combustion gas stream
most people cannot go grab a flue pipe and be happy.
