Inducer Motor Gasket - HVAC - DIY Chatroom Home Improvement Forum
Old 12-03-2010, 09:15 PM   #1
Inducer motor gasket
I had a new inducer motor installed on my furnace a few months back. I am now getting a burning smell when the furnace runs. I was told that it could possibly be the silicone that was used to seal the gasket. Could this be correct and if so will the buring smell go away?
NeedSomeAdvice is offline   Reply With Quote
Old 12-03-2010, 09:47 PM   #2
High temp silicone shouldn't be effected by temps under 600 degrees. The flue gas does not get anywhere near that hot.
Old 12-03-2010, 09:56 PM   #3
Hvac Pro
yuri's Avatar
Rewards Points: 1,396
Burning smells can be dangerous. May have a cracked or blocked heat exchanger or flame rollout from the burners which can produce CO Carbon Monoxide. Get it checked ASAP. Don't trust your HDepot CO detector to protect you from that. They are meant for large amounts of CO like from a blocked chimney etc.
Old 12-03-2010, 10:30 PM   #4
This is my first winter in the house. I am in the process of trying to get an entire home efficiency audit done because the house is not retaining heat. The furnace is continually going of so they sent over one of their HVAC techs. He is the one who stated it is probably the silicone.
Inducer installation / modification ... caseywa HVAC 26 12-06-2010 02:50 PM
Why is Inducer Fan Running? artbuc HVAC 3 07-31-2010 10:39 AM
New pressure switch and inducer and still incorrect drafting kevintabb HVAC 5 01-19-2010 01:59 PM
Pressure Switch, Draft Inducer, Burner Box, Problem majorapus HVAC 7 10-25-2009 07:14 PM
Heil furnace inducer vibrating, capcitor handling question diggerdave HVAC 45 03-01-2009 05:56 PM
