Inducer Motor - HVAC - DIY Chatroom Home Improvement Forum
Old 12-04-2012, 11:38 AM   #1
inducer motor
i have no power to the inducer motor on my furnace ,could it be my circuit board is no good
dacoolman is offline   Reply With Quote
Old 12-04-2012, 11:40 AM   #2
i have no power to the inducer on my furnace could it be my circuit board
Old 12-04-2012, 11:51 AM   #3
Items wanted: Time
Rewards Points: 150
Could be, can you determine if the furnace is getting a call for heat?
NiNe O is offline   Reply With Quote
Old 12-04-2012, 03:04 PM   #4
inducer motor
when i turn up my tstat to 25 my blower motor will start and on my thermostat it says heat on ,i know the blower motor should stop after 90 secs then the inducer motor should start but nuttin happens i checked for power there is none ,,,,
Old 12-04-2012, 03:06 PM   #5
there is no power going to the inducer motor
Old 12-04-2012, 03:34 PM   #6
Items wanted: Time
Rewards Points: 150
Why does your blower run for 90 seconds before a heating cycle? What furnace? Model number?
Old 12-04-2012, 04:05 PM   #7
the furnace is a heil dc 90 ultra model #ntgmo75ega2 heil is really keeprite
Old 12-04-2012, 08:40 PM   #8
JJboy's Avatar
Check the voltage....no voltage replace the control board.
**Always kill the power ** Hot air rises, but heat will always move from higher to lower temperatures. ** Real man shoot in manual. ** If it ain't grounded, it ain't dead.
JJboy is offline   Reply With Quote
Old 12-05-2012, 06:07 AM   #9
Items wanted: Time
Rewards Points: 150
you have to make sure the furnace is getting a call for heat first. Are there any codes that the control board displays via led light blinking?
Lennox inducer motor bracket mmm97m HVAC 13 11-20-2014 08:12 PM
replace repair fasco inducer motor myronl HVAC 4 11-19-2011 07:59 PM
Inducer Motor not drawing enough vacuum for switch? HELP! tigeraid HVAC 13 10-18-2011 02:33 PM
Bryant Plus 90 398AAZ inducer motor PCWilson HVAC 10 02-27-2011 04:55 PM
Inducer motor or control circuit? Please help me troubleshoot. averagerob HVAC 1 03-03-2009 01:43 PM
