Inducer Installation / Modification ... - HVAC - Page 2 - DIY Chatroom Home Improvement Forum
Old 12-14-2006, 04:49 PM   #16
Thoroughbred Mopar Man
Rewards Points: 502
Hi caseywa
The biggest difference I would say, has to be the motor torque. What relevence it has to the situation could be minimal. The one you have now is a capacitor run motor, these motors are slightly higher in torque than a shaded pole motor. You could be talking about as little as a couple of inch pounds, but the engineer designed it with this in mind. Like I said I can't tell you the exact difference. You may be able to go to the Fasco sight and compare the engeneering data. I am not sure if that is available though. I hope I didn't confuse you.
Good luck
Rusty
#CARRIERMAN is offline   Reply With Quote
Old 12-14-2006, 07:13 PM   #17
You didnt....the motor rpm and fans are the same. Pulled the old apart and the new. The A142 is on the furnace now and running fine. More details later, having big storm and the power is about to go out here.
caseywa is offline   Reply With Quote
Old 10-04-2010, 09:43 AM   #18
How is it Working?
Caseywa,
I found your old post as I was looking for the exact same blower motor today.
Could you tell me how it has been working for you?
I followed with interest the idea you put forward about installing your own drain plug at the bottom and would like to know how that panned out.
Thanks.
Pinckney12 is offline   Reply With Quote
Old 10-04-2010, 06:46 PM   #19
Originally Posted by Pinckney12 View Post
Caseywa,
Thanks.
The blower has been working great for what looks about four years now. And the drain plug is working perfectly. I found the blower online... I am not sure if I mentioned where I ordered the blower from in my post or not, let me know if you need and I will hunt around from where I got it. I kept the old blower in case I needed parts or got around to repairing it for a back up.
Casey
Old 10-05-2010, 06:53 AM   #20
Blower
Hi and thanks for responding so quickly.
If you have any information on where you got it that would help my search immensely. Don't mean to put you to any trouble but I keep running into brick walls with my search.
Thanks again!
Old 10-05-2010, 04:47 PM   #21
Thanks again!
Ken at supplystuf.com
Old 10-17-2010, 10:26 AM   #22
Fasco follow up
Hi Caseywa,
I just noticed you replied to me and I neglected to say thanks.
I looked at supplystuf.com and it was an ebay site and I tried emailing ken@supplustuf.com and got a bounce back on the email. Could you shed any light on this dilemma? If not, no problem but I would appreciate any further help you could give.
Old 10-17-2010, 11:19 AM   #23
Hi Caseywa,
You got the email wrong, it should be: ken@supplystuff.com
...and try searching the web for: supplystuf.com
...it is an ebay site.
Old 10-17-2010, 11:39 AM   #24
Hi Caseywa,
Also read this thread from this website:
Inducer Part Needed: Please Help!
and...
Bryant Inducer Motor
Old 10-18-2010, 12:13 PM   #25
Problem Resolved
Thanks for all your help. Having had the service tech tell me I needed a new motor because the bearings were shot I embarked on this search process.
Well, I tore into the inducer one last time yesterday and this time, by pure chance, discovered that behind the squirrel cage fan were some tiny objects. While bending the squirrel cage to create a 2-3 mm opening I was able to pull out 3 tiny pebbles; maybe the size of BBs. I have no idea how they got there as we are in a finished basement. Anyhow, these pebbles were grinding and jamming the fan to a stop, but now that they are gone, the motor is working like a top.
This is one of those rare stories of money saved during a house maintenance project, and I thought I would pass it along.
Thanks again for the help you gave and the time you spent giving it.
Old 10-18-2010, 06:39 PM   #26
I am just an everyday homeowner like yourself, great to hear about the happy ending...
Old 12-06-2010, 01:50 PM   #27
Hi Carrierman, I also have a Fasco inducer blower that wasn't working because three of the fan blades inside the unit broke off and got stuck. We took the inducer out and clean the fan and put in back. The motor seems to be working fine but there's no heat. Some how the burner is not litting up. Any ideas what may be causing it? Thanks for your reply. I checked the gas lines and it were on.
Aziza007 is offline   Reply With Quote
Inducer Part Needed: Please Help! BDPNA HVAC 55 12-08-2010 08:48 AM
Aluminum Soffit and Fascia Installation... MoparAutoworks Building & Construction 1 12-17-2006 07:46 AM
Fan Inducer Supplier found rookie50 HVAC 2 11-30-2006 11:45 AM
Replacement Inducer Blower caseywa HVAC 18 11-27-2006 03:42 PM
trane furnace with inducer blower error tjh57 HVAC 1 10-22-2006 07:45 PM
