Inducer Fan - HVAC - DIY Chatroom Home Improvement Forum
Old 10-28-2010, 08:35 AM   #1
Inducer fan
Hi
I have a 5 year old American Standard single stage Freedom 80 counterflow furnace. I have noticed recently in the morning when I turn the furnace on the draft inducer comes on it runs real long and then it shuts off like it could not get a vacum. It then comes right back on and acheives a vacum quickly and the furnace runs normal. The furnace then seems to run pretty much normal. Is it maybe because the vent is to cold and it is taking to long to get a draft ? or I am going in the wrong direction
Jeff
jprince is offline   Reply With Quote
Old 10-28-2010, 09:24 AM   #2
Hvac Pro
yuri's Avatar
Rewards Points: 396
Could have a leaking vacuum hose to the pressure switch or blockage in the port on the inducer fan/collector box it attaches to or failing switch. May have a blockage in the chimney or dead bird in the exhaust fan. Remove the smokepipe where it attaches to the top of the furnace and look inside for said dead bird or feathers (yes it happens).
Old 10-28-2010, 10:07 AM   #3
Thanks for your reply. I will check the vent I don't think a bird could be in there because I have hardware cloth over the cap on top but i will check anyway and thanks for your other advice I will keep an eye on it
Inducer installation / modification ... caseywa HVAC 26 12-06-2010 01:50 PM
Why is Inducer Fan Running? artbuc HVAC 3 07-31-2010 09:39 AM
New pressure switch and inducer and still incorrect drafting kevintabb HVAC 5 01-19-2010 12:59 PM
Pressure Switch, Draft Inducer, Burner Box, Problem majorapus HVAC 7 10-25-2009 06:14 PM
Heil furnace inducer vibrating, capcitor handling question diggerdave HVAC 45 03-01-2009 04:56 PM
