Inducer Blower Replacement - HVAC - DIY Chatroom Home Improvement Forum
Old 11-15-2012, 08:19 AM   #1
I purchased a replacement inducer blower motor. It looks pretty easy to install. The model is: Furnace Draft Inducer Blower (Goodman J238-112-11064) 115 Volts Fasco # A157
It has two wire connections, but doesn't have +/- or black/white key on the motor itself. Does it matter how it is hooked up? I have a black wire and white wire in the furnace. I also have a hose connection, but that seems obvious. Any help on this motor is appreciated!
homerookie is offline   Reply With Quote
Old 11-15-2012, 09:36 AM   #2
Rewards Points: 492
It doesn't matter.
See video (and others) on Youtube.
diyorpay is offline   Reply With Quote
Old 11-15-2012, 09:18 PM   #3
I installed the new inducer motor. But it doesn't seem like its getting any power. I tried the wiring both ways, but no joy. I reset the breaker as well as the thermostat, no joy. Anyone have any ideas of what could be the issue?
Old 11-15-2012, 09:59 PM   #4
how
Rewards Points: 1,102
First establish that the thermostat circuit is good by removing the stat wire from the "R" connection within the furnace and then putting a jumper between R & W. If that does not start up it up , confirm that the furnace is getting 120V, the door switch is working, the inducer is getting 120V and that the board fuse is OK.
how is online now   Reply With Quote
Old 11-15-2012, 10:02 PM   #5
You're not getting any juice to the motor.
Could be in the connections to the board or the board it self.
Not likely but possible is also your new motor is bad.
hvac5646 is offline   Reply With Quote
The Following User Says Thank You to hvac5646 For This Useful Post:
ben's plumbing (11-16-2012)
Old 11-15-2012, 11:17 PM   #6
Rewards Points: 492
As How stated, make sure blower door is on or at least the door switch is temporarily rigged to 'engaged' position to complete power circuit.
Explain why ID fan was replaced? What were symptoms?
Old 11-16-2012, 06:47 AM   #7
I had to replace the inducer blower because 2 of the "blades" in that squirrel cage busted off, was a loud morning. It also damaged 2 more of the blades. I thought it would be best to replace.
Old 11-16-2012, 07:46 AM   #8
Rewards Points: 582
make sure you have 120 volt going to inducer at heat call...ben sr
The Following User Says Thank You to ben's plumbing For This Useful Post:
mrairflow (11-17-2012)
Old 11-17-2012, 08:30 AM   #9
Rewards Points: 492
CAREFULLY unhook from board power and supply power from an extension cord. Rig your jumper wires from female end to ID fan terminals and plug in extension cord last.
That will test the fan.
58mxa inducer blower replacement vyp HVAC 1 03-14-2011 10:59 PM
Furnace & Replacement inducer blower louiel HVAC 2 12-28-2010 11:28 PM
New inducer blower toboggan HVAC 2 01-19-2010 05:28 PM
Fireplace blower - motor replacement kelley4180 Remodeling 3 12-20-2009 07:38 AM
Replacing Inducer Blower allenzachary HVAC 8 12-28-2006 01:42 AM
