Inducer Blower Motor Noise - HVAC - DIY Chatroom Home Improvement Forum
Old 10-04-2009, 02:37 PM   #1
inducer blower motor Noise
My inducer motor for my home furnace is making a high pitched noise. They HVAC guy came in and said that I need a new inducer motor assembly. Is there a way to tighten the pre existing assembly to reduce the noise. It seems when I put pressure on the motor, the noise disappears.
Does is seem that the inducer motor needs to be replaced? Would tightening the motor make a difference on on the assembly?
Thanks!
snwboarder45 is offline   Reply With Quote
Old 10-04-2009, 03:34 PM   #2
biggles's Avatar
give the area between the squirrel cage and where the shaft goes into the motor a couple of shots a WD40 with the extension tube.shaft might be rubbing on housing reposition squirrel cage...make sure the squirrel cage round fins are clean.
Old 10-04-2009, 06:20 PM   #3
If, a few days after tightening, the noise returns, yes.
Old 10-05-2009, 10:48 AM   #4
Reponse to WD 40 + Motor
I only have access to one side of the inducer motor. Would spraying WD 40 be enough if only sprayed from one side of the motor?
Picture attached.
Old 10-05-2009, 11:33 AM   #5
Unlikely.
Get a nutdriver, power off, take out the assembly.
Or rig up some coat hanger wires or some kind of fixture to press the motor into a direction where the noise goes away.
It's a kluge but it may work for quite a while.
Your only symptom so far is noise, and pressure seems to fix it.
If the noise means metal-to-metal contact it may also grind down and cure itself, but don't hold your breath.
Old 10-05-2009, 11:39 AM   #6
thanks. I have pressure on it now, seems like a temporary fix.
Furnace will not stay on allenzachary HVAC 32 09-21-2010 09:30 PM
Replacement impeller and clip for Heil exhaust inducer blower iixeb HVAC 2 01-09-2009 09:36 PM
Need inducer blower wheel sonnygentry HVAC 3 01-05-2008 01:12 PM
Replacement Inducer Blower caseywa HVAC 18 11-27-2006 04:42 PM
trane furnace with inducer blower error tjh57 HVAC 1 10-22-2006 08:45 PM
