-   -   inducer blower motor Noise (http://www.diychatroom.com/f17/inducer-blower-motor-noise-54411/)
snwboarder45 10-04-2009 02:37 PM
My inducer motor for my home furnace is making a high pitched noise. They HVAC guy came in and said that I need a new inducer motor assembly. Is there a way to tighten the pre existing assembly to reduce the noise. It seems when I put pressure on the motor, the noise disappears.
Does is seem that the inducer motor needs to be replaced? Would tightening the motor make a difference on on the assembly?
Thanks!
biggles 10-04-2009 03:34 PM
give the area between the squirrel cage and where the shaft goes into the motor a couple of shots a WD40 with the extension tube.shaft might be rubbing on housing reposition squirrel cage...make sure the squirrel cage round fins are clean.
Yoyizit 10-04-2009 06:20 PM
If, a few days after tightening, the noise returns, yes.
snwboarder45 10-05-2009 10:48 AM
Reponse to WD 40 + Motor
1 Attachment(s)
I only have access to one side of the inducer motor. Would spraying WD 40 be enough if only sprayed from one side of the motor?
Picture attached.
Yoyizit 10-05-2009 11:33 AM
Unlikely.
Get a nutdriver, power off, take out the assembly.
Or rig up some coat hanger wires or some kind of fixture to press the motor into a direction where the noise goes away.
It's a kluge but it may work for quite a while.
Your only symptom so far is noise, and pressure seems to fix it.
If the noise means metal-to-metal contact it may also grind down and cure itself, but don't hold your breath.
snwboarder45 10-05-2009 11:39 AM
thanks. I have pressure on it now, seems like a temporary fix.
