Induced Draft On Same Flue As Natural Draft - HVAC - DIY Chatroom Home Improvement Forum
Old 12-08-2009, 02:29 PM   #1
induced draft on same flue as natural draft
Hi
I read somewhere that you have to be careful if you have say an induced draft fan furnace on the same flue as a natural draft appliance such as a hot water heater. It said that fumes could be forced out of the draft hood. Will this even happen if you are venting the smaller appliance such as the hot water heater above the draft induced furnace?
Skippy
Skippymartinez is offline   Reply With Quote
Old 12-08-2009, 07:14 PM   #2
An old Tradesmen
Rewards Points: 6,112
Yes.
If the chimney becomes restricted, the furnace will vent out the water heaters dilution hood.
Good chance it already does, when the chimney is cold. Until the furnace warms it up a bit.
Draft Inducer Blower Not Blowing- LED Blinking 3 Times rust101 HVAC 10 04-09-2013 09:44 PM
Pressure Switch, Draft Inducer, Burner Box, Problem majorapus HVAC 7 10-25-2009 07:14 PM
Ruud gas pack kills 2nd induced draft blower?? TurningWorm HVAC 2 02-01-2009 12:21 AM
