Indoor Heat Pump Drawing In Unfiltered Air - HVAC - DIY Chatroom Home Improvement Forum
Old 12-18-2011, 03:52 PM   #1
sweaty
Rewards Points: 276
I have a Carrier heat pump. The filter is a washable one, 20' X 21.5", with a metal frame. Above it is a 20" X 0.5" gap that draws in unfiltered air. How do I close that gap while still being able to remove the filter for cleaning?
sweaty is offline   Reply With Quote
Old 12-18-2011, 03:55 PM   #2
AKA HVACTECHFW
Rewards Points: 1,208
have a sheet metal shop or a tech make you a door
IT IS WHAT IT IS
hvactech126 is offline   Reply With Quote
Old 12-18-2011, 04:18 PM   #3
use a 20 x 25 x 1 filter......the extra 5 inches will stick up above the slot, giving you a "handle" to grab when changing the filter, making it much easier to change the filter.
harleyrider is offline   Reply With Quote
Sump Pump Questions henlij Plumbing 22 03-16-2015 10:00 PM
Intermittent submersible pump fault esquilax Electrical 5 09-30-2011 03:56 AM
Sump pump operation MikeKy55 Plumbing 16 05-11-2011 04:35 PM
Well Pump Problems dannyjoe Plumbing 6 10-01-2009 06:10 PM
Modification to an existing pump switch DRBLKJK Electrical 10 08-23-2009 03:06 PM
