Indoor Coil Is Hot When Unit Is Off.... - HVAC - DIY Chatroom Home Improvement Forum
Old 10-12-2011, 07:28 PM   #1
Indoor coil is hot when unit is off....
I have a HEIL unit, not sure of the actual model, but the mfr # is HAC036AKA1.
The indoor coil (I guess it's called the evaporator coil) has frozen a couple times this summer, but moreso because I was using filters that were too thick. I downgraded to a cheaper grade filter, and it froze once more a couple weeks ago.
I turned the unit off and let it thaw (I helped it out a little with a hair dryer), and it seemed to work fine after that.
The last few days I have noticed that the evap coil sits unusually hot when the unit is even completely off.
Any ideas? I rent this house, and everytime we've had a problem the last couple years, our landlady usually sends her maintenance guy out to check it, instead of a licensed HVAC service contractor.
I'd really like to know what the heck is going on so she doesn't give me the runaround yet again.
TIA.
sgt. osiris is offline   Reply With Quote
Old 10-12-2011, 07:58 PM   #2
Is this a gas furnace, or a heat pump?
Master of Cold is offline   Reply With Quote
Old 10-12-2011, 08:07 PM   #3
It's electric, so I'm guessing it's a heat pump.
Old 10-12-2011, 08:08 PM   #4
So when you say evaporator, are you referring to just the coil, or the entire cabinet?
Old 10-12-2011, 09:49 PM   #5
The coil. Cabinet underneath feels relatively normal.
Old 10-13-2011, 12:11 AM   #6
I'm Your Huckleberry
Rewards Points: 2,270
Where is the evaporator located in the home, basement, closet or attic?
Btw, just because you have electric heat does not mean you have a heat pump, it means you have electric heat strips in an air handler. Not saying you don't have a heat pump (we'd need the make and model of your outside unit to be certain) as gas or electric could be secondary heat...
Doc Holliday is offline   Reply With Quote
Old 10-13-2011, 12:13 AM   #7
Are we talking the inside evporator coil? If so then you'd literally have to open up or remove the panels of said coil/air handler to even get to the coil and I'm not sure why you'd be doing that, just to touch it I mean.
Old 10-13-2011, 12:17 AM   #8
It sounds like the electric heat is on.
Old 10-13-2011, 12:36 AM   #9
It is in the laundry room.
BTW...totally forgot... I did call an HVAC guy today for pointers , and without much help, he did say that based on the 1st 3 letters in the model #, it is not a heat pump, but an A/C with heat strips.
Make/ model are in my OP.
Old 10-13-2011, 12:42 AM   #10
Hmm... I did turn the heat on about a week ago when it got down into the 40s one morning.
Could it be the thermostat, or the heat strips stuck?
Old 10-13-2011, 04:47 AM   #11
Ok, I just thought of something.
I'm a real novice here, so I don't know the part, but it seems like I remember something I googled last night mentioning some sort of heating mechanism that keeps the coils from freezing over. What is that thing called? Because, it's fine when the A/C is running-normal temp. And, the A/C puts out pretty cool.
Only when it's off does it heat up like it does.
The other semi-helpful thing that the HVAC guy I called told me was that if the heat strips are stuck, then my power meter outside would show rapid usage.
So, I checked my meter with the heater off, and the meter's usage bar (digital meter) cycled very slowly, indicating minimal power consumption from lights and a TV. But, when I turned my heater on, the thing cycled much more quickly, showing increased power consumption.
So, I'm not really sure if the heat strips are the problem. If the heat/heat strips was/were on, it would show more power consumption on the meter than it does.
BTW, to answer a previous question, the coils are easily reached from the main return vent on my unit.
Old 10-13-2011, 08:45 PM   #12
Do you have a voltage meter?
Old 10-13-2011, 09:07 PM   #13
As in, a multimeter? Yes.
Old 10-15-2011, 09:10 PM   #14
Do you know how to tell the size of the heat strip?
Old 10-15-2011, 11:28 PM   #15
No clue..
Ruud Pack unit "KABOOMS" upon First Light Up of the Day! Wirenut2tite HVAC 18 12-15-2012 11:11 AM
Had an Aire-Flo AC installed, looking for opinions mikemcd HVAC 14 08-01-2011 05:07 AM
new r-410a ac unit installation procedure(w/old unit r-22)? excalibur1 HVAC 0 06-06-2011 04:47 PM
Window A/C Unit and Supplying Power JayEnder Electrical 1 04-30-2011 08:50 PM
Inside Unit Runs, Outside Unit Runs (with help) no cold air beakon20 HVAC 4 08-13-2008 10:33 PM
