Indoor AC Vents..should I Cover Them? - HVAC - DIY Chatroom Home Improvement Forum
Old 03-27-2010, 09:37 PM   #1
Indoor AC vents..should I cover them?
Should I cover the intake and plug the discharge vents in the winter? I have a large (14" X 25") intake and about a dozen discharge nozzels in the ceilings.
D
StahlMaster is offline   Reply With Quote
Old 03-27-2010, 09:57 PM   #2
Military Mom of 4
Snav's Avatar
If air/cold is coming in while unit isn't engaged then you can cover with magnetized sheets. . .and consider covering your outside unit if it's only used during the heat for ac for further protection from the frigid elements.
At this present moment in time I am making cabinets for the kitchen - just in case you wanted to know what I'm doing when I'm not around.
Snav is offline   Reply With Quote
Old 03-27-2010, 10:17 PM   #3
Is this a packaged unit that sits outside?
richiemoe is offline   Reply With Quote
Old 03-27-2010, 10:29 PM   #4
The unit sits in the attic. I have hydronic heat.
I'm more concerned with the warm air excaping up into the intake and into the discharge.
D
Old 03-27-2010, 10:39 PM   #5
Then i would say it would not hurt anything thats for sure. I can understand why you would want to do this.
Old 03-28-2010, 01:12 AM   #6
retired elect/hvac/plumb
plummen's Avatar
Location: south east of omaha/The island of misfit contractors
Rewards Points: 2,020
i usually tell people not to cover condensing units in the winter,traps moisture and causes corrosion
plummen is offline   Reply With Quote
Old 03-28-2010, 07:49 AM   #7
Rewards Points: 1,216
My air handler is in the attic all my vents are feed from that and my return air is in the ceiling of the hallway 20x25.
I shut the power off to the air handler, close all the louvers on the supply vents, take the filters out of the hallway and close off the 20x25 hole with 2 pieces of insulated duct board and reinstall the grill.
Remember hot air rises and all your heat will go through the vents to the attic.
The outside unit I do nothing to it, it's made for the weather like cars are.
If I was going to anything to the out side unit I would probably put a small piece of plywood on top with a brick to hold it down just to keep leaves and branches from going in the top. Do not cover tight with plastic it will ruin the unit let it breathe.
COLDIRON is offline   Reply With Quote
Old 03-28-2010, 09:26 AM   #8
Military Mom of 4
Snav's Avatar
Good point, plummen and coldiron.
Old 03-28-2010, 11:14 AM   #9
An old Tradesmen
Rewards Points: 7,814
Since you said nozzles. I guess that means you have a high velocity system.
They make plugs for your supply outlets for that very reason.
Old 03-28-2010, 12:18 PM   #10
Yep, I've got the 2" plugs. A few were damaged so I got 2" caps from mailing tubes. Work great.
I'll look into putting a piece of foam insulation over the 14" X 25" intake.
D
ridge vents vs. box vents vs. turbine vents redaws Roofing/Siding 12 03-12-2012 09:48 PM
How to cover up ceiling vents in basement... Goldglv HVAC 7 07-09-2009 08:27 AM
Ridge vents and/or fan? mama2girls Roofing/Siding 20 05-27-2009 07:12 AM
ridge/soffit vents not enough?? cbice74 Roofing/Siding 1 06-16-2008 05:02 PM
Fascia cover filled with water/ice causing leaks brianbh Roofing/Siding 10 02-11-2008 07:34 PM
