Inconsitent Air Flow - HVAC - DIY Chatroom Home Improvement Forum
Old 12-18-2011, 09:26 PM   #1
Rewards Points: 14
inconsitent air flow
i was walking around my place and noticed, some vents pump out air and others barely have any flow. i have a attic where they vent from, what can/should i do about this?
bryanp is offline   Reply With Quote
Old 12-19-2011, 04:29 AM   #2
An old Tradesmen
Rewards Points: 8,154
Are any of the ones not moving much air, returns?
The Following User Says Thank You to beenthere For This Useful Post:
plummen (12-19-2011)
Old 12-19-2011, 06:21 AM   #3
Rewards Points: 14
No, we only have 1 return and its attached the hvac unit.
Old 12-19-2011, 09:56 AM   #4
I'm Your Huckleberry
Rewards Points: 2,270
The vents that are moving the least amount of air are usually the ones furthest from the unit. Also if the duct runs are Y'd off (one main trunk splitting into three) then that can be the issue as well.
Generally location on the plenum (where the duct takes off from the unit) is a big deal as well as being dedicated runs to individual vents.
For now you can check for any possible leaks and check to see if you have any dampers (air flow control doOrs in the duct's themselves), usually located at the plenum.
Thanks.
Doc Holliday is offline   Reply With Quote
The Following User Says Thank You to Doc Holliday For This Useful Post:
Old 12-19-2011, 10:32 AM   #5
Rewards Points: 14
how would i check for leaks? crawl around and feel for air? or is there a scientific method?
Old 12-19-2011, 10:38 AM   #6
incense candle stick thingamajig, very scientific. turn on the system and crawl around and feel for leaks as well as hold that lit incense stick at all connections. watch the smoke.
check the return as well.
Thanks.
Old 12-19-2011, 10:56 AM   #7
retired elect/hvac/plumb
plummen's Avatar
Location: south east of omaha/The island of misfit contractors
Rewards Points: 2,020
Once you fix any leaks if you dont have enough air in certain rooms you can always close some other vents in closer rooms part way to force more air to other vents.
How many rooms dont have cold air returns?maybe try leaving the doors open on those rooms to help get some air back to furnace .
Has filter been changed?
plummen is offline   Reply With Quote
Old 12-19-2011, 11:44 AM   #8
Rewards Points: 14
its a small place and only has 1 cold air return.
we leave all doors open usually. ill try closing the vent and seeing, but the pressure between the one vent to the other is immense.
one vent you get showered with air, if you sit under it, the others you put your hand to the vent and barely feel any air.
Old 12-19-2011, 11:48 AM   #9
plummen's Avatar
thats why you close the vents getting a lot of airflow part way to force more air to other vents
Old 12-19-2011, 01:42 PM   #10
Closing off supply registers is not a good solution. Your duct system is designed to move a certain amount of air, and when you close off supplies, it can't do it. It will likely force air out the other vents, but will cause an increase in your static pressure, and not moving enough air can cause a host of other problems.
brandonmcginnis is offline   Reply With Quote
Old 12-19-2011, 01:50 PM   #11
plummen's Avatar
sometimes you dont have a lot of other options
Old 12-19-2011, 03:08 PM   #12
There are always options. Closing off registers is almost always a bad one. It sounds like he needs to make some duct modifications. Closing off registers is going to cause an unnecessary temp rise, which means high head pressure if it's a heat pump, or an over temp condition across the heat exchanger if it's a furnace. Both of those conditions WILL lead to bigger problems than poor air flow.
Old 12-19-2011, 03:10 PM   #13
closing off, be it partial or completely, registers will hardly if at all affect sp. closing off dampers at the plenum will.
Thanks.
Old 12-19-2011, 03:55 PM   #14
An old Tradesmen
Remove the return grille, and see if you get more air out of any of the supplies.
Old 12-19-2011, 04:50 PM   #15
plummen's Avatar
so make a suggestion!
I thought I understood plumbing, private well flow rate question ChrisDIY Plumbing 22 07-25-2011 10:14 AM
Moving HVAC ducts/registers & reverse flow ?'s cbrc5eric HVAC 3 06-09-2010 05:05 AM
Flow switch use in Hydronic Heating System sarlaud HVAC 14 02-02-2010 07:03 AM
Hot water faucet pipe thumps then flow slows down. DIY-Indy Plumbing 9 07-15-2009 11:09 PM
very low shower head flow rickard681 Plumbing 7 10-08-2008 06:43 AM
