Improving Air Pressure - HVAC - DIY Chatroom Home Improvement Forum
Old 07-19-2010, 08:09 AM   #1
So I bought a house that has a new AC unit installed and notice that on the side of the house closest to the Air Handler the registers blow cool air with some good flow. But on the other end of the ranch the air pressure is considerably lower. Is there a way to pull more cool air down to the other side of the house with some force? Right now my bed room is right over the Air Handler, and it gets quite cool in my bed room whereas the other side of the house is a few degrees warmer.
DAdams982 is offline   Reply With Quote
Old 07-19-2010, 07:06 PM   #2
Hvac Pro
yuri's Avatar
Rewards Points: 382
Get a experienced tech with a airflow meter (velometer) to check the flows and balance the ductwork. He will close a few, measure the results in the further rooms and check the freon pressure etc to make sure the coil does not freezeup.
Old 07-20-2010, 03:00 PM   #3
Rewards Points: 89
I know they sell fans that are made to blow the air in between the ducts. However, that will require you to run electrical wiring to the fan also.
Another simple solution is just to close off the vents that are blowing to strong. I remember working in a business that had uneven airflow. That place did not have vents that are adjustable. So I just tie a big knot around the duct where the air was blowing to strong and it increase the air flow in the weaker ones.
You stated it is a new A/C. I would probably check with the guy that installed it. Assuming that all the duct is new also, I'm wondering if they used the wrong size duct for warmer side of the ranch.
stanlam is offline   Reply With Quote
Old 07-20-2010, 04:01 PM   #4
Yeah it is original duct work... all galvanized tubing... not the flex stuff. I am probably going to spray foam around where the vent pentrates the floor, there is tons of air seepage around there, then try shutting down some vents. There is some 13 runs coming off the AC unit.. so thinking it just gets choked off before the length of the house. One thing is that the air isnt as cool on the warmer side of the house by the time it reaches that register, so i am in the process of wrapping the duct work in Reflectix, see if that holds the cool a little better.
Old 07-20-2010, 04:02 PM   #5
So basically balance the registers by closing some down? My registers now are pretty flimsy so wouldnt rely on them to hold back any flow... is there any company that you would recommend on registers?
Intermittent Low Water Pressure Fox Plumbing 4 03-02-2010 06:04 AM
Older air compressor wiring help lash-1295 Electrical 91 12-23-2009 12:46 PM
Pressure Switch, Draft Inducer, Burner Box, Problem majorapus HVAC 7 10-25-2009 06:14 PM
New Pressure Switch -- low water pressure chach Plumbing 4 01-18-2009 09:50 PM
New Help With Improving Water Pressure hayhursm Plumbing 1 01-31-2006 06:55 PM
