Improving Air Flow/block Return Vent - HVAC - DIY Chatroom Home Improvement Forum
Old 06-26-2013, 07:18 PM   #1
improving air flow/block return vent
Hi,
I have single zone unit to cool 3 levels. Lowest level of course is coolest with highest level warmest. It was suggested to me to improve cooling at the higher level, to block the return located at the lowest level of the house, thus improving the draw from the return vents located at the upper levels of the home. I have scoured the internet to confirm this approach as an effective one, but no luck finding anything that even suggests this approach.
Anyone have thoughts to share?
thanks, Paul
pcarmi is offline   Reply With Quote
Old 06-26-2013, 07:28 PM   #2
biggles's Avatar
are the 3 returns ducted back down to the air handler furnace? you have a supply duct and return duct up thru the middle of the house and the stat location is?
The Following User Says Thank You to biggles For This Useful Post:
pcarmi (06-27-2013)
Old 06-26-2013, 08:03 PM   #3
I believe the returns are ducted back down to the air handler/furnace. all three returns are located in the middle of the home. the stat is located on the main (middle floor).
Old 06-27-2013, 04:05 AM   #4
REP
It might help a little,but its not fixing the problem.I am not a real big fan of zoning hot air units ,but it sounds like that might be the way to go in your situation.
REP is offline   Reply With Quote
The Following User Says Thank You to REP For This Useful Post:
pcarmi (06-27-2013)
Size if return vent ey218 HVAC 1 08-13-2012 03:41 PM
Reroute return air vent to help with sound. westtx28 HVAC 1 07-23-2012 04:30 AM
Converting a return into a normal vent? Red Squirrel HVAC 0 11-04-2009 08:58 PM
return vent size change philip18 HVAC 7 10-24-2009 11:18 PM
Return air vent question sidewayzisbest HVAC 5 05-10-2009 03:39 PM
