Improved Air Quality Question/Help - HVAC - Page 2 - DIY Chatroom Home Improvement Forum
Old 02-25-2012, 03:40 PM   #16
Thanks again. I've got a call into a contractor. Right now what I've been using is the 3M Filtrete 1900 1" which is a 12MERV. I found a Filtrete 2400 but it's a 10MERV. I thought the MERV number determined the size of the particle the filter could capture which also drove the amount of air restriction. Is this true or and I wrong?
Tiberian is offline   Reply With Quote
Old 02-25-2012, 05:47 PM   #17
Hvac Pro
yuri's Avatar
Rewards Points: 2,318
Google MERV for more info. The higher the merv the smaller the particle it captures but to do that it needs to be finer/denser and that reduces airflow.
Old 02-26-2012, 08:33 AM   #18
Do you guys know of a good thermostat that has a cycle setting for just the fan?
Old 02-26-2012, 08:46 AM   #19
An old Tradesmen
Rewards Points: 7,414
Honeywell IAQ.
Old 02-26-2012, 09:07 AM   #20
Hvac Pro
yuri's Avatar
Yep. It has a ability to run the fan for 20 mins/hr for circulation which would be a good idea for you. If you get a bypass filter you can have it run all the time even with the furnace fan off and it will help but you still need the fan on for 20 mins to improve the circulation and get a better result. NOT cheap to buy though and quite tricky to install. Need a skilled tech to do it. Probably looking at close to $750 or more to have it installed.
Indoor air quality check D-rock General DIY Discussions 4 10-31-2011 08:57 PM
Quality Heat only Programable Thermostat rjordan393 HVAC 3 01-16-2011 02:31 PM
REEB millwork quality sucks tuckerz Building & Construction 0 12-10-2009 10:52 PM
Recessed Lighting - Quality Question. 811Gibbon Electrical 8 01-24-2009 09:47 PM
Entry Door Quality -- Questions About Manufacturers I G Norant Carpentry 1 07-27-2006 09:05 PM
