Improper Insulation Installation??? Help!! - HVAC - DIY Chatroom Home Improvement Forum
Old 07-04-2007, 11:30 AM   #1
Rewards Points: 12
Question
I have a dilemma and I canít find the answer online. I have a 1940ís cape in Massachusetts. The upstairs of the house is typical of a cape. The Living space down the middle of the house and crawl space on the front and back of the house. The upstairs gets incredibly hot in the summer. Iím not sure how to remedy this problem. The house has a ridge vent and thatís all. However the living space is completely covered in fiberglass insulation. The knee wall is insulated and the ceiling is insulated. From what I can tell this insulation is blocking any airflow to the ridge vent. Is this correct? If not how do I keep the heat / AC in the house and let the crawlspace ventilate properly? I donít know if this makes a difference, but there is no insulation under the floorboards in the anywhere upstairs. I have only been in this house for 2 years and this work was done within the past 7 years. Iím desperate to make it correct before it starts causing real damage.
truebaca is offline   Reply With Quote
Old 07-04-2007, 12:34 PM   #2
Do you have soffit vents?
Is there any form of an attic?
redline is offline   Reply With Quote
Old 07-04-2007, 02:45 PM   #3
Lic. Builder/GC/Remodeler
AtlanticWBConst.'s Avatar
Understanding Attic ventilation:
http://www.factsfacts.com/MyHomeRepair/ventilation.htm
http://www.gaf.com/Content/GAF/RES1/...ventchart.html
More information (2 pages - more information on page 2):
http://www.thisoldhouse.com/toh/know...194780,00.html
- Build Well -
Old 07-04-2007, 02:47 PM   #4
Also: Ed The Roofer (on this site) can really help you with this:
http://www.diychatroom.com/members/ed-the-roofer-7225/
- Build Well -
Cape Cod Style House Attic/Crawl Space Insulation Help Danielg Insulation 24 05-21-2012 09:20 AM
Improper Installation of Steel Composite Tub House_Amuck Plumbing 1 03-19-2007 04:50 PM
Aluminum Soffit and Fascia Installation... MoparAutoworks Building & Construction 1 12-17-2006 08:46 AM
Installing new insulation in my basement and removing the old moldy insulation. Fixitgeorge Remodeling 3 10-17-2006 09:33 PM
Insulation material reusable? KUIPORNG General DIY Discussions 4 06-19-2006 03:38 PM
