Immersion Heater - HVAC - DIY Chatroom Home Improvement Forum
Old 01-28-2004, 12:24 PM   #1
Guest
Guest
Posts: n/a
Immersion heater
I turned on my immersion heater for two hours not knowing another family member had drained the hot water tank. The insulation on the outside of the tank got so hot it started going brown and making crackleing sounds.
Does anyone know if the immersion heater will have been damaged by this or will it be ok to just refill the tank and use as normal.
Old 02-17-2004, 09:31 PM   #2
Sounds like it is going to be cracked
but try it good luck
watch for leaks as soon as you start filling it
kachas is offline   Reply With Quote
Installing a tankless water heater ? bdalekid Plumbing 3 02-26-2007 07:26 PM
Chimney Liner for Water Heater mruggeri001 HVAC 6 01-10-2007 06:08 AM
Wiring electric heater in bathroom PatSea Electrical 5 01-06-2007 09:40 PM
Baseboard heater Help! jweinstock Electrical 6 10-28-2006 04:01 PM
Periodic release from (I think) the T&P valve on the water heater alexz Plumbing 3 08-15-2006 10:31 AM
