#1 |
1921 Sears&Robuc
Immediate help needed please! Gas co. coming out in the morning~
Hey folks for some reason i just knew i would be needing some help!
I decided to go ahead and remove the access panel from the electrical, and gas side, and found a sticker i didnt want to see! ATTENTION THIS VALVE HAS BEEN CONVERTED FOR USE WITH LP GAS!!!!!!!! Help! What parts do i need to retro it back to natural gas, gas man coming in the morning(between 1000hrs and 1400hrs) That gives me a few hours in the morning or maybe this evening if i can get the parts, please help if you can! This is a GOODMAN PGB-030100-01 92000BTU ![]()
My house, a 1921 Sears-Robuk 1 1/2 story 4 bedroom, 2 bath 1975 sqr ft house! Ordered March 1921, delivered via: railcar 1922, assembled October 1922! Ignorance is not having the knowledge of', Stupidity is having the knowledge of' and not using it! |
#2 |
Electrician
Look around the furnace area for a package/envelope with a spring and nozzles and possibly a spring adjustment cap. Typical NG to LP conversions (or vise versa) require changing the injection nozzles on the burner rail and the adjustment spring (sometimes along with the cap) on the gas valve.
In your 'upper' photo, the white plastic cap, in the center of the photo, appears to be your adjustment screw. The spring would be under there. You should also have the gas valve output pressure set with a manometer. A local HVAC co. can do that for you. Remove the 'LP conversion' label after the unit has been converted to NG.
Kyle Just because you can, doesn't always mean you should |
#3 |
the Musigician
i've done ng to lp conversions before, it's not too hard. if you are not confident doing it yourself though, i'd call the gas guy in the A.M. and let them know the problem, they'll usually do the conversion for you for an added fee. but be sure to let them know if you do not already have the conversion kit so they can bring one. this way you will know it's safe too. but what do i know? i'm just a mouse.
DM Last edited by DangerMouse; 10-05-2008 at 04:47 PM. |
#4 | ||
1921 Sears&Robuc
Immediate help needed please! Gas co. coming out in the morning~Quote:
#5 |
the Musigician
well, if they WON'T do it, and you can find the kit and follow directions, it is a simple fix. just follow directions exactly and you should be fine.
DM |
#6 |
the utility will put in a new 24V gas valve and be done with it $$$$$$,the conversion kits are from nat.gas to lp gas and they aren't going to convert you back.if your confident enought do the valve yourself check out www.grainger.com for over the counter sales to DIYers locally if it is stand alone pilot 24V direct and in/out on the piping 3/4 to 3/4 or 3/4 to 1/2 they have them
#7 |
1921 Sears&Robuc
do i not need to replace to the orifeces as well as the gas valve? Or will i be ok replacing the gas valve and all my problems are fixed?
My house, a 1921 Sears-Robuk 1 1/2 story 4 bedroom, 2 bath 1975 sqr ft house! Ordered March 1921, delivered via: railcar 1922, assembled October 1922! Ignorance is not having the knowledge of', Stupidity is having the knowledge of' and not using it! Last edited by MrShadetree0222; 10-06-2008 at 12:22 AM. |
#8 |
the orifices are different for the 2 gases the utlity tech might have them if you go with him on the changeout.
#9 |
1921 Sears&Robuc
Issue Is Dealt With Noi Further Assistance Is Needed At This Time!
| Display Modes | |
| Size of whole house fan needed | Doug Crf | General Discussion | 20 | 02-26-2011 12:29 AM |
| screws coming loose | Baffeled | Building & Construction | 4 | 08-13-2008 09:48 AM |
| Toilet: water still coming from BOTTOM of Inlet Valve | DIY Mom | Plumbing | 1 | 08-12-2008 01:43 PM |
| propane smell coming out of new unit | jlachey | HVAC | 3 | 04-09-2008 12:12 AM |
| Furnace troubles, where's the water coming from... | Head Scratcher | HVAC | 10 | 03-23-2008 08:40 PM |
