Old 12-30-2008, 03:02 AM   #1
Question
Im having problem with utica boiler pce
Hello guys Im having a problem the heater wont go on when the thermostat say it should. I went down stairs to check the pilot is on but it wont heat up. Ive checked the thermostat its showing number so i dont think its the battery on thermostat. I reset it and did it again and no it wont go on. What can it be?? I see the glass tube there is water in a littlemore than half.
ceasar201 is offline   Reply With Quote
Old 12-30-2008, 06:14 AM   #2
Wethead's Avatar
nATURAL or propane?
Need Help With Your Pump?►
► Watch Me On YouTube:
► WHPR On Facebook:
► We Have Helpful Pump Articles!
Wethead is offline   Reply With Quote
Old 12-30-2008, 06:45 AM   #3
An old Tradesmen
Possible.
Open roll out switch.
Bad high pressure switch.
Dirty/clogged Low Water Cut Off.
Bad thermostat.
Defective gas valve.
Old 12-30-2008, 01:08 PM   #4
The utica boiler is useing gas and the pressure is at 8. is that good? the pilot is on it just wont burn?
Old 12-30-2008, 03:28 PM   #5
An old Tradesmen
Is that 8" at the manifold, or at the gas valve inlet.
By on, do you mean the valve is turned to on, but no pilotflame.
Or the pilot flame is burning, but the main burner won't light.
Old 12-30-2008, 03:32 PM   #6
i see the little flame of the pilot on but it wont all tuirn on all the fire so heat go up thats the onything it wont do but there is light of pilot.
Old 12-30-2008, 03:37 PM   #7
Is this boiler steam or circulated water.
SKIP4661 is offline   Reply With Quote
Old 12-30-2008, 03:44 PM   #8
An old Tradesmen
Then you need to check the things I listed. Any of them can cause the gas valve not to open.
Plus the 24 volt transformer.
utica boiler ignites for 5 sec. then shuts off UBoiler HVAC 17 07-21-2008 10:40 AM
Utica Boiler shut down problem halo HVAC 2 02-29-2008 08:41 PM
Corrosion problem in vent stack. sgbotsford HVAC 2 12-01-2007 03:47 PM
Steam boiler corrosion problem franklopes HVAC 4 11-09-2006 09:02 PM
