I'm Finding Chunks Of (cellulose) Attic Insulation In The A/C Registers.... - HVAC - DIY Chatroom Home Improvement Forum
Old 04-09-2011, 10:06 PM   #1
Question
I'm finding chunks of (cellulose) attic insulation in the A/C registers....
...which leads me to thinking there must be a leak. A BIG leak as these are close to pinky sized pieces of cellulose that are getting stuck on the register before the duct from the forced air unit reaches the inside of the living room.
Now, I've gone up into the attic and looked for leaks but cannot find any. The connections to the main AC are sealed with mastic and the ducts seem okay when I check them as I crawl out to the register.
When I wipe away the cellulose from where the duct connects to the ceiling register, I don't see any major cracks or openings in the seal (we also are having a dust and respiratory issue with the cellulose insulation is why I was looking at this).
So anyways, If there's no leak in the duct (that I can see) from the AC unit to the register...and there's insulation getting in there somehow...where else could it be?? How is this insulation getting into the unit?
Any advice for my next trip up into the attic?
I know it may be hard to give advice with only this rough sketch to go on...feel free to ask me questions, we need all the help we can get. We're a young couple with kids trying to Do It Ourselves and save a dime (or two) ...before calling the pros to get the ducts cleaned and all that.
Thanks in advance.
AnotherGuy is offline   Reply With Quote
Old 04-09-2011, 10:29 PM   #2
An old Tradesmen
Rewards Points: 6,550
Seal the register boxes to the attic floor. The air blowing through them causes a slight negative draft which can pull in dust and insulation.
The Following User Says Thank You to beenthere For This Useful Post:
AnotherGuy (04-09-2011)
Old 04-09-2011, 10:34 PM   #3
Will check that, thanks.
Tags
a/c ducts , cellulose , cellulose insulation , duct , leaky duct
AC Flex Duct - Suspend above attic insulation or lay it on top? fritzycat1 HVAC 13 08-17-2011 11:19 PM
Insulation, Ventilation in Cape Cod Side Attic Get'n er done Building & Construction 10 12-03-2010 12:38 AM
Attic insulation over the cavity above the stairs jkocher Building & Construction 5 10-15-2010 10:03 AM
Rafter Vents and Insulation nofx1981 Roofing/Siding 15 03-10-2010 09:14 PM
Attic Insulation covelle Building & Construction 8 01-08-2010 10:45 PM
