I'm Dumb And Need Help. - HVAC - DIY Chatroom Home Improvement Forum
Old 07-28-2011, 06:02 PM   #1
I'm dumb and need help.
I am a first year apprentice in a commercial/industrial mechanical equipment service union. The contractor I work for was able to get me a new heat pump at their cost for my house to replace the old one when it broke. I took a huge paycut for this job and can't even afford to pay one of my work buddies to help me install it, much less a residential contractor. I want to be able to install it myself. I have a carrier 2- ton 410A system. It's an upflow a-coil, and so far I've got the a-coil connected into the the ductwork, and ran the drain line. I've ran the new line set and I basically just need to pipe it up and wire it up. I also mounted a new thermostat. I know little about wiring diagrams and refrigeration but obviously I will need to in my trade. ( I just started working last month). I've arranged to borrow some equipment (gauges, refrigerant, vacuum pump, nitrogen for a purge/vacuum, and a torch set and such) from a co-worker tomorrow so I can hopefully finish it this weekend.Can anybody walk me through wiring this thing? I can provide any information you need. I'd like to get it all wired up so once it's charged I can fire it up and finally get some AC (it's been a long hot summer).
A Loose Canon is offline   Reply With Quote
Old 07-28-2011, 06:18 PM   #2
JJboy's Avatar
Stage 1:
Welding the line set ( Use N2 )
Install Liquid line filter drier
make sure you cover with wet cloth any component that is near the welding
Let me know if you have any question on the first stage,
**Always kill the power ** Hot air rises, but heat will always move from higher to lower temperatures. ** Real man shoot in manual. ** If it ain't grounded, it ain't dead.
JJboy is offline   Reply With Quote
Old 07-28-2011, 06:23 PM   #3
Hvac Pro
yuri's Avatar
Rewards Points: 396
Removing the schraeder valve cores might help before you weld er up.
If you have never installed a system it is not as easy as it sounds. Very easy to overheat/damage/ruin the service valves, get leaks from bad welds, moisture in the system etc. I would try and trade some services/labor (help him move or shingle his roof or whatever) with one of your guys who knows how to do this and watch and learn from him.
Old 07-28-2011, 07:26 PM   #4
An old Tradesmen
Rewards Points: 8,188
Buy that co worker some beer and have him help you. have a BBQ for him.
Old 07-28-2011, 07:32 PM   #5
Hvac Pro
yuri's Avatar
Rewards Points: 396
Most guys will work for Beer and a BBQ and it is a good way to get to know him/your co-workers. If he is good at his job he can hook it up in 4-6 hours on a Saturday.
