Im Corn Fused - HVAC - DIY Chatroom Home Improvement Forum
Old 10-08-2008, 06:14 PM   #1
Unhappy
im corn fused
i moved in to a house and some one disconected the heat duct from one side it has heat on one side of the house and not the other. so i bought a 25ft peice of insulated flex duct i just finshed hooking it up and the heat on the one side is great but the other side is not so great so whata YOU think
thanks
chmemakowski7 is offline   Reply With Quote
Old 10-08-2008, 07:46 PM   #2
You probably have less press to feed the cold side of the house now you hooked up the duct.
Does the rest of the house have flex duct or round pipe?
hvaclover is offline   Reply With Quote
Old 10-08-2008, 09:28 PM   #3
gotcha
its rectangularer it has two ten inch drops that were both pluged with wood so i took thoes out and hooked it in
Old 10-09-2008, 08:06 AM   #4
A little more info please.
What are the rectangular dimensions (or round diameter) of the ducts that you hooked to on both ends, what is the size of the diameter of flex duct you used, is that 25' run going through unconditioned space, and is the piece you ran actually 25'? Also, what part is now cold, the part that used to be warm, or the part you are trying to get heat to?
When using flex duct remember to keep it from sagging or kinking.
dac122 is offline   Reply With Quote
replacing a fused subpanel ltlbud36@comcast.net Electrical 15 08-10-2008 05:05 PM
Removing Vinyl Tile Adhesive from Linoleum The Raven Flooring 3 07-22-2008 08:38 PM
fused disconnect and/or GFCI ? pchiz Electrical 8 12-21-2007 10:02 AM
